[ROM][BETA] Quattrimus ICS (ZVD)
what do you guys do with the voicemail? i found a working virtual voicemail that has no draw problems and what not but whenever i get a voicemail i get that stupid 9016 text saying i have one
and the block 9999 thing didnt work and if i block it with say call blocker i dont get the voicemail
Google voice...be sure to go to your phone app and change the settings so voicemail doesn't go to sprint (that's how it works with gVoice)
Sent from my LG-LS670 using Android Central Forums
I use YouMail. I may not get transcripts, but I really don't need them. It lets me "ditch" callers.
Yeah usually it says I'm under 20mb left....then sometimes it says I have 60mb left lol! Kind of confusing...
so i cant seem to send mms, sms is fine and i can receive mms pic but i cant send em, i still have the stock mms that the rom came with and what not, just wondering if anyone is in the same boat or if im doing something wrong...
I reported the same issue the other day but it seems that only some of us are actually experiencing it.
think a reflash would fix it?
I was having a similar problem in the earlier versions. Gosms app seemed to be the way around it. But I did a full wipe when I flashed beta 2 and everything seems to be working nicely in the factory SMS app.
On another note I'm having problems once again with Pandora just constantly loading and never buffering the song. Also having a problem with not receiving calls but I have a feeling that has something to do with Google voice.
How's everyone doing on battery life now? I use to get by pretty well but I installed Beta2 CM9 a few days ago and I'm struggling to make it through a day...
(Min at 122 with Smartassv2, little use of data, mostly on wifi or nothing)
Mine lasts about 4 hours before it needs to be plugged in. It will last a little longer if I dont turn the screen on. lol. As soon as I do anything that involves the screen being on the battery life plummets......drastically.
I get fantastic battery life. Literally fantastic. I'm set at 245/729, performance. Yesterday, I unplugged at 8am and plugged back in at 10pm with 63% battery. That was after 10-12 phone calls (one lasting 8 minutes),20-25 text messages, 2-3 emails.
I did a complete wipe before installing beta2. I also try to reboot 5 or 6 times after installing.
On a different note, has anyone noticed that there are beaucoup changelogs, but no new nightlies?
Dang you two are at some serious extremes lol!
I have noticed the nightly thing though.
Nightly builds have been bumpy. The build server was down for two nights, there have been code sync errors, etc. I'm working on a project that I'm calling multi ROM also. And both cm and aokp have moved on to jb.
We should have nightly builds again next week, but really they aren't needed anymore.
akashisensei
