[ROM][BETA] Quattrimus ICS (ZVD)
I hope you didn't take offence to my post I just reread it and I was in an ill mood earlier.
Sent from my LG-LS670 using Tapatalk 2
Not at all.
Although I'm hoping the dev or someone else has the stock calendar apk handy. I deleted it because I use Gemini but I'm having a hard time with Gemini so I need to reinstall the original calendar. Usually I have backups... usually....
Anyone?
TDM you're awesome
I've been hunting this for the past week, glad you found it :) I didn't think to look in serial, I was seeing the error thrown from the hsfp module, IIRC. I've been literally and figuratively bandwidth limited lately. A new i7 is in my future, methinks.
Should be in the 7/30 nightly, right?
Reactions: tdm
Fyi, found my calendar problem... I didn't have the calendar sync and storage files pushed. Gemini works great now.
Just curious if there is a reason why there is no change log?
Regardless love CM over AOKP just seems more stable to me.
Just fixed a bug in the build script that caused the changelogs to only appear on vmroms.com. Find previous logs there, and starting tomorrow they should appear on all sites.
Oh and BTW, if you don't monitor the OV thread, BT reboot has been fixed with today's build.
Glad to hear that, thanks for all your hard work. Anyway to get a link to the changelogs? I looked for it but cant find it on vmroms.com
Do you have to do a clean wipe with every nightly update?
Sent from my LG-LS670 using Android Central Forums
I did a few without clearing anything, but at one point I felt things were just a bit slow so I did a clean update. You can try it without clearing but if you get bugs I would do a full wipe and fresh install.
Reactions: Sdude1200
I'm having trouble using adb with cm9. It acts like I don't have root.
hanspl
