[ROM][BETA] Quattrimus ICS (ZVD)
I just installed this and it was in the boot screen for a good 5 minutes and it finally got to the 'Welcome to the LS-670' screen and I click the Android and it says 'Unfortunately, setup wizard has stopped'... What am I supposed to do bout that?
I believe it has something to do with the Gapps package I installed because it was normal up until the point I installed the gapps.
Tdm I believe just added a mirror for the small gapps most of us use. Check the op. :cool:
Not yet, probably tomorrow morning.
And I'm probably going to stop using goo for a mirror, I'll just use it for tossing out files to individuals to test.
What's the difference between quattrimus beta 2 & cold as ice alpha 15?
Also can someone point me to the direction to a changelog to quattrimus beta 1 & beta 2. Thanks:D
CAI is rather similar to Q-CM9. TheKraven and I shared a lot of stuff back and forth.
Q-AOKP is .. well .. AOKP. Search around for descriptions and screen shots.
I don't have a changelog between beta1 and beta2. And if I did make one, it would be in git shortlog format. So probably not very readable.
Been using beta1 for awhile now and I just flashed beta2 and encountered an issue, but it may be limited to me. For every ICS build on my phone I've had to manually go in and set the "GPS Source" to "Internal GPS Antenna". I've never made a post about it because it hasn't been a real issue, but that option seems to be missing in beta2. Any way to set this manually somehow with a file edit or shell command or something? I would love to be running the latest and greatest.
I believe it's settings> location services> gps source..then it gives the option to select internal
I didn't change the gps stuff, maybe cm did?
Damn I thought that might be the case. Now I'm wondering if they removed it as a setting altogether because wouldn't it carry over if it was just hidden? (I did a dirty flash over beta1)
Yeah that is where it used to be but it's just not there anymore:
Reactions: wormy987123
Android OS made changes to third party access to features like GPS starting in ICS. They denied access, period. Found out with some automation apps. Used to turn on GPS when an app started, no more. That might be it and not CM work.
Sent from a GNex w JB 4.1.1 & Tapatalk 2
Maybe this is why my navigation and maps don't work?
Well I'll be damned. I still have the setting for GPS source and I selected internal, uninstalled maps, reinstalled and it works great now! Fr33dan, try a clean flash and see if its available then cause I'm on Beta 2 and its still available to me.
I'm on beta2 with a extra clean flash and I have no GPS setting like that. Didn't have it on my nightly either... oh well..lol
I'm trying to install a themed keyboard and I have like no system space left anybody(tdm) know what system apks are safe to remove? Thanks
LeslieAnn had a detailed post in the ov forums, it might be stickied.
Usually, the live wallpaper stuff and any extra themes and wallpaper apps are a good place to start.
That's what I use is small gapps.. I deleted aokp tips, unicornporn and the round clock. Oh also the stock keyboard. I'm running darkice keyboard and an ics themed mms apk.. me rikey..lol thanks fam..:). Edit: do not delete the clock, no alarm without it...dirf
Reactions: strabo231
Greenfid28
