[ROM][BETA] Quattrimus ICS (ZVD)
Google debug format all. Its a zip that's wipes the whole system in one step. Or there's a triple wipe floating around that wipes everything you guessed it 3 times..lol on another note format boot system data cache and dalvik cache if your wanting to go manual.
Yeah. All video playback tends to lag on AOKP. Not sure about CM9 version
Sent from my LG-LS670 using Xparent Red Tapatalk 2
Only HD video on CM9 will lag; while Normal video looks like mud, it plays fine.
Sent from a Purple LG-LS670 with CM9...the New Wolzard Phone...yes.
Couple of things.
First I'm on an Ls670 Optimus S running Quattrimus CM9
1. Clock Lag: Seems to do it not matter whether it's set to use network time or not, it does update a bit faster if the network time is turned off. As a workaround, I installed the clock apk from drews CM7? I'll let you know how it works out.
2. GPS antenna, the option is there for me also, and my maps and nav work fine.
3. My best battery life. full two days processor set at Min:122, Max: 748. (Crashes the phone if I set it above 800) CPU Governor Conservative.
True but I'm a sort of youtube junkie, esp when I'm not near my computer. Meh...I'm probably a more isolated case haha
So the gingerbread clock workaround doesn't do anything. It crashes actually whenever the application is actually run, and it still has update issues.
Has anyone found a way to mail the emails not disappear from the screen when you open them? It happens on the built in email app, and the downloaded Gmail app as well.
Hey I'm on Quattrimus Beta 2 AOKP and I've noticed I have only installed 10 or so applications and I go to install another one and the warning will pop up saying 'Internal Storage is full'. I go to 'Settings' and look in 'Storage' and it says 18 MB of Internal storage left, then I look in 'Apps' and in there is says I have 102 MB free of internal storage.
Hey, sorry for the long delay, life got in the way. The option never appeared but one day I forgot it wasn't working and loaded maps and it just worked. I don't know but I think it may be related to the recent Google maps update. Either way thought you might want to know it's working now.
Hey tdm I remember you had aosp
What worked and what didn't do u remember
Sent from my LG-LS670 using Tapatalk 2
I don't remember, but when I get it built again, it should have everything same as cm9 and aokp.
just flashed this rom great ics for this phone havent encounter any issues yet the optimus i flashed the rom is my tester. nice job by the way what recovery is eerybody using
Was that directed towards me?
Hope it gets built soon it would make my day :D great job tdm keep it up
Also if I'm on aokp can I dirty flash onto cm9
sheiela
