[ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
How do you change the boot animation?
Using a file manager, like root explorer or ES explorer, you can go to where you downloaded the boot animation you want, change the name to bootanimation.zip. Then move it to system/media and overwrite the one there.
EDIT: I now see what you mean. I don't see the bootanimation.zip file in system/media
Sent from my ZombieBean-VM670 using Xparent Blue Tapatalk 2
It should be somewhere under the cyanogenmod settings.
So is it possible to change the boot animation?
And just a quest does anyone else see like the dots at the bottom of the screen? Does anyone know why they're there?
Does anyone know an app that can clean the phone? Like so theres more room and that can clean the SD card?
Well if you're partaking in any of the new INT2EXT scripts...any cleaner will do. I personally use a pair, Android Assistant and CacheMate Pro (I have a sizable Google Play gift card...went on a spree recently). Used in tandem, they're combined effective.
is anyone getting a "unable to install to usb storage or internal memory" message from the Play Store when installing and/or updating apps you already paid for?
Can you give me a link? Last time i tried to create an ext. It didn't work and i lost all my sd card contents
Unless you have your SD card contents backed up somewhere, either on the cloud, a flash drive, your hard drive (portable or internal), I don't recommend doing SD partitioning via recovery and no offense to the wonderful recovery creators, don't exactly trust the function either.
I have always done my partitioning on my Windows laptop (not totally clear how it'd work on a Mac though). I use the free version of Easeus Partition Master (which is the first part of a three-pronged suite) to do so. It is extremely easy to use...
Settings-> ROM Control-> General UI. It's the first option at the top.
Not seeing the dots here
The dots are really little, like the very bottom of the screen.
How do i enter USB mass storage?
And i changed recoveries from zen garden to cannibal open touch, and all my back ups wont work any help?
Battery drain is supposedly a feature Of Google Now across devices. I'm getting great battery life on PAC Rom. Try disabling GNow Background Location options!
Sent from my LG-LS670 using Android Central Forums
That was it! After disabling Google Now, my battery drained 5% overnight instead of 50%.
Also, these ROMS are using the same kernels as CAI, right? So USB fast charge is in the kernel? Charging seems really slow on my car charger.
ok i used Easeus Partition Master so what do i do now? do i reflash the rom? or what? sorry im new to this.
I figured you might need help with EPM, but now there's no doubt that app is so easy to use! Is it EXT3 or 4? Your ext partition should be no more than 20% of usable space (on a 32 gigger, its around 29.7 usable, so 5.94 gb max on the partition) For me, EXT3 seemed to work better on my OC settings (768/480) than 4, which caused frequent reboots.
I'd reflash the ROM in the following sequence:
ROM
Gapps
INT2EXT (or the + version, whichever you prefer)--the fixed one in Page 7 somewhere, there's links for that
The Virgin Fix
Optional---but if you do, this should be done last! Flash the 39 or 40 kernel (links in the OP). Why? You have to wipe dalvik-cache after the kernel flashes.
Then profit. Restore whatever apps you have in backup (tiBU or whatever app you use tyo backup apps). If you have Gmail as part of the app backup, restore app only, no data, redo everything for Gmail. If you restore the data portion of Gmail, you'll lose the ability to send out e-mails and they get stuck in the Outbox. Only remedy is to wipe the data for the app.
ROM
Gapps
The Virgin Fix
i made a EXT2... itsa 8gb sd card, and i made a 2gb ext...
ZVD to ZVJ patch worked, but both INT2EXT and the v40 kernal kept my phone from booting. It just spins on the CyanogenMod boot screen forever.
Ok it went this time when I used this link [SCRIPTS]CronMod-INT2EXT (updated 02/28) - xda-developers instead of this link [SHARE]INT2EXT app2sd solution and SWAP2INT swap on internal solution - xda-developers, it took forever but then I got a screen that says "Android is upgrading..." and it's optimizing my apps.
Once this goes through I'll make another backup and try upgrading the kernal too.
Ok i made the ext, and when i follow the instructions on page 7 from xda and when i boot my phone it says i have 2gb of internal storage, but the phone is really laggy and rhen freezes i pulled the battery and when it boots up it starts over at the welcome screen, or all the apps i downloaded are gone and its as if i just flashed it. Can anyone help?
Sent from my VM670 using Android Central Forums
Which one works? The + one? Or other?
byronsss
