[ROM][CM10][JB] Euroskank JellyBro
i got 726 gapps from euro site but my g+ pcs arent showing can flash the gapps n the posts above me the 715?
Just found that flashing themes from theme manager will break my lock screen slider settings.
Beamed from my GneX via TaPaTalK. ;)
The Nav bar changes are excellent. I no longer need to flash the custom ones.
Here are some suggestions for the next revision of this useful addition...
- How about a phone option like ThunderStick does. It'd be fantastic to have a phone option anywhere.
- I'd love to see apps as options.
Great work this is fantastic. I'll never buy a phone with hard buttons again. Not when I can customize the buttons.
anyones ringer keep going to silent all by tself
Check your quiet time settings, I had mine off for most of the day and couldn't figure that one out for a long time.
oh. but you said ringer...hmmm thats weird.
atleast i learned thing was a thing as "quiet settings" lol so your post wasnt that bad lol maybe its my gapps lol m having issues with gallery and dylan said to try another gapps pkg but dont know where to find them and when do can just flash them lke normal or do have to flash rom again too
Whenever I can't figure anything out I just flash my backup and start over. (If you don't have a backup then just start all over and wipe EVERYTHING.
ok Im confused . Which gapps (and do you have a good link?) should I be using?
I'd initially go with what Jellybro recommends.
euroskank (this has no syncing with Picasa though) (I don't sync w/ Picasa so no big deal for me)
I'd direct you too goo.im ( http://www.google.com/url?sa=D&q=ht...ed.zip&usg=AFQjCNGee-Sxf3nWMt_W3lbOeYIliDlidQ ) but they are down for the weekend reconstructing their website. (These are as OFFICIAL as you can get)
The above Xoomdev build will/should hold you over. POST #436
Then JAkeday makes some good gaaps too, might be worth a try....> http://d-h.st/zek
But the Roll Royce of GAAPS seems to be here.....> http://rootzwiki.com/topic/31532-gapps-411-398337-jro03c-gapps-package-081112/
Reactions: jmiesse134
It's the "latest" custom Gapp build out there right now, (calendar syncs/PicoTTS removed by author, latest google apps that Play Store doesn't even have, author claimed) Not sure why but it's there. (might start a thread on GApPS)
That sounds great a gapps thread with an op that links to all the usable gapps and an explanation of the differences too.
Reactions: JkdJedi
What's the difference between the 8/11 gapps and the custom gapps
Check the first post on that thread. Custom has a few things removed and added a few up-to-date google apps which currently are not available in the Play Store (Books, Currents,etc)
The regular version is based on the structure of how the normal GAPPS are packaged together.
Reactions: DB12088
I flashed the 8/11 gapps but didn't know if I was missing anything with the custom gapps
sulagmu1
