[ROM][CM10][JB] Euroskank JellyBro
I am unable to send pics while WiFi is enabled...although this is a known Gnex issue, I noticed that the JellyBelly ROM recently included a fix to this issue. Is that something that can actually be added to a ROM? If so, that'd be great to see here!
So is that Lock Screen deal working now or in Beta, can't get mine to stick. The Octopus setting where you can swipe to 5 different angles and select which app (opens) in the lock screen.
It's always worked for me. Reflash?
I also flashed AOKP today to check it out. I like some things (circle battery mod, fully customizable navbar=dpi/color/glow) but it's lacking in other things (CM10/Skank has more extensive toggles and lockscreen options).
So I think I'll end up back on JellyBro as well. Btw, is there a circle battery mod for JellyBro?
Don't know if you're using a theme or not, but the one I am using, vivid blue, has the circle battery as its icon setting.
Use Kejar's 7/15 GAPPS with your ROM. I have been able to send MMS over WiFi with that GAPPS.
Reactions: KillerQ
No love for me on this last build. Flashed back to the one we got this morning and will wait and see what tomorrow brings.
What issue did you have? I found this build to be the best performance yet. Both in quality and speed.
Sent from my Google Galaxy Nexus using Tapatalk 2
Reactions: 7stringer
This build is flying for me. Did a last minute before bed DF, so the kernel has been soaking all night. Lol
Deep sleep has been awesome. Went to bed at 94%, woke up this morning at 94%. I'll take it.
Found this under the XoomDev directory in Goo.IM. So far, so good!
Thanks!
FWIW, those were replaced by his 7/23 package for the rom that they were built for--the RootzBoat one, IIRC.
Thanks!
Honesty, all of these custom Gapps scare me - lol. Theoretically, I could flash his updated package that you mentioned, right?
Thanks!
7/23 AOKP GAPPS works great as well. I've just stuck it out with the 7/15 gapps without any issues. MMS over WiFi works, picasa sync works, etc.
sulagmu1
