[ROM][CM10][JB] Euroskank JellyBro
On the latest build (0926) as well as older ones (all clean installs), I get a force close when you go into settings/sound/music effects? I'm trying to set Volume + as my music effect, but always get the FC. Does this happen to everyone else, or do I have some other issue (maybe with Volume +)?
Is there a forum / thread on this ROM that is way more active? This quiet time is KILLING me!
Sent from my toaster (rooted).
I don't even see the music effects settings on my phone.
It's the mixer turquoise theme. The softkeys are from my stash, easily changed in rom control. If you want em holler.
The mixer themes don't work on official aokp. (unlock slider does nothing). Works fine on skank.
Sent through the Verizon LTE network. (;))
Definitely, that theme is quite nice if you can hook it up :).
What's the difference between this dsp manager and the DSP already included in the ROM?
It's Dre Beats awesome.
Beamed from the future via Tapatalk
The theme is in the play store. Search for mixer cm10 theme. It comes in most any color and best of all its free. I like the icons and busy animations over other themes.
Here are the softkeys...I'm sure you know how to install them.
One more question... the font you use, how would I be able to get that font?
I used to change fonts alot, but I really like this one and haven't changed it in a long time. A little edgy but not out of hand. It's called neutra text and don't worry about the ics in the filename, works fine on the bean. Do the ol flash in recovery.
Nice font. How does one go about changing it on the phone?
They are zip files flashed in recovery just like a rom, no wipe necessary. There are a whole bunch in a sticky in the theme section at rootzwiki.com.
Thank you. I will check out rootzwiki :thumbup:
WoW! is it just me or is this new Skank zippn along a lot smoother now...like everything is...... INSTANT.
Do you have the link? I couldn't find it on rootzwiki. Tia
Xray app found a vulnerability, I'm running Euroskank and was wondering if anybody else was seeing this in their phones as well.
Edit: Seemed to be from a beta kernel (Faux) I flashed over the todays nightly, I flashed a different kernel (franco) and that cleared things up.
hakuntata
