[ROM][CM10][JB] Euroskank JellyBro
It's a great rom, currently running it with trinity kernel and all is right with the world :).
Where can I get the Trinity Kernel? I hear people like that as an alternative to Franco.Kernel and right now I use the Franco.Kernel updater app to get that and later releases. Does Trinity have one too?
I'm still not able to mess with the display colors. Can someone, anyone help?!
The vibration is grayed out too.
You should be able to change colors under Advanced in settings
I'm dumb. I forgot I could add screen shots. I attached them so I can show what's going on.
I asked this question in the General Q&A so I'll figure it out somehow.
How do you flash a new kernel? Is it the same as flashing a rim?
Anyone know of this ROM has navigation bar customization?
*edit* nevermind! I was confused at a question and answered incorrectly.
Don't know if this is a ROM issue but my volume levels are constantly changing. I've tried a couple of apps that are supposed to lock the levels but they don't work.
One example is last night when I went to sleep I had all the levels turned off. Woke up and they were all set at some random level.
maybe you have ghosts?
jk it could be the rom, i suppose. you did a clean install?
you dont have any profiles set up?
Yes clean install and no profiles
it could just be a bug. if it keeps happening i would swtich to aokp or something for the time being.
you don't have children do you??? :)
other than that, there may be a possibility that it's the kernel or something, but that seems less likely to me than the rom having some bug or something. ive never had my volumes change randomly, just more typical bugs such as random reboots, hang up on boot screeen, etc. with euroskank builds.
I flashed 804 a few hours ago. Running good BUT no camera. I installed Pudding Camera but I like the stock one better.
That's not the ROM. Maybe you flashed the wrong gapps? You can try flashing a different gapps over your current one. Which gapps did you use?
Haven't had time to even flash 804 so I'll just hold out till tomorrow anyways.
marik999
