basketthis
- Nov 22, 2010
- 1,470
- 473
- 0
So basically I'd have to revert to zvd to use this rom which is better than a zvh rom? Jw if the logic is right.
Its probably the garbage adw browser all together. I had issues with adw and the ex version also. Downloaded launcher pro and haven't had a single issue.
Sent from my LG-LS670 using Tapatalk
Thanks Kraven, 10.10 build running fast & smooth with no issues, looks great!
Can I use the center clock patch from the previous build with this build?
9/19 still used Drew's Xionia Redux. If you are having problems with USB and wifi, I'd try flashing the latest Xionia Redux kernel dated 8/31. Only downside was gameplay graphics with that one. But a stable Kernel. If you want to try that on a later build, I'll need to make a keypad button correction file for you.
How high are you all overclocking?
I was getting an error with car home saying no activity, but after I installed Google Maps the problem went away.
Also, when i hold down on the home screen, i don't get a menu, it just interacts with the nexus live wallpaper. Anyway to fix that?
Right now cm7 is not available for ZVH. It is being worked on but for now, yes, you must be on ZVD baseband in order for this Rom to work correctly. "Better" is a tough word to justify. I suppose it all depends on your experience with ZVH as everyone's is different. It seems to have messed up some peoples phones and not done much to others. Either way, cm7 is a great Rom and if you haven't used it before, it may be worth reverting just for you to see what it has to offer!![]()
wow...manny29 asked this same exact question a few pages back and got his head bitten off for it. From what i learned, pergersons is the proper response. DONT ASK!!!
