[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Been trying to fix problems with Windows 7. I'll PM you and Seller's today. :)
I already know your problem, its windows 7 lol. Take your time I look forward to the awesome sauce
Yeah. Took my PC, formatted everything, lost some stuff, but not to important, installing fresh, again, now. :p
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
Good luck. :)
Finished the build.prop already, I will send it to you right now , you were missing the treshold for tablet mode and configurations were all mixed up and you had some duplicate strings that was causing crashes in the system.
Reactions: ThatGuyLurkin
Well artist. Settings still FC for me. I'll work more tomorrow and release something for people.
I was able to get bottom task bar.
Just settings force close. I can't test mic, I need to pay bill. :p
Amd I do that right after the settings force close, correct?
Its only build.prop making the settings force close. It was specially made by Neko I believe.
do a reboot, then start the logcat then go into settings. anything marked with an E is an error
also, id recommend opening settings multiple times during the logcat, just so you know for sure that the error is the right one. stop the logcat immedietly after opening settings for the last time, this will make it easier to find.
elowen89
