[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Is there a bottom status bar yet?????? When their is I shall test
Sent From AOKP BABY YEEEEEHA!!!!
Bottom status bar doesn't affect a thing. Its just a look.
You can except an update this week.
Maybe bottom bar, Fixed mic hopefully, updated, 10% chance of Paranoid settings.
Here's the thing, if I add bottom task bar, we wont have a functional keyboard. The dpi needs to be 85 I believe for taskbar.
Wow kool
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
You manage to get the mic working so I can make calls and such normally and this will be my daily :D
Are there going to be any update on this rom soon?
I've been working on it. Having trouble booting because of LCD DPI
Thanks for the update, :) .
I've been geeked for a stable version of this rom ever since you uploaded.
If there is anything I can do to help pm me and let me know, i mean im not a dev or anything but ill do whatever i can to help.
That's how all of the great devs started!!:D best of luck guys! Enjoy!
Ok. I got it booted. Again. Still no bottom bar, because of the build.prop
1: Booted, New, No bottom bar, no settings, etc.
2:Booted, Bottom bar, NO DATa, Settings work, and all.
In the S forums, He ported wrong. The Build.prop destroyed the Data. He's supposed to use the one from Quattrimus, or CAI, not P500
I like number 2 only because I use my S as wifi only.
Sent from my LG-LS670 using Android Central Forums
Should be, yes. I'll release number 2 for those of you who want to mess with it.
Those ICS nerds out there, I need help with the build.prop to get it going. Maybe I'll contact Cole2bk(SORRY! I forgot what it was). I know he was good with it.
BarishYadav
