[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
The screen fitted when I changed the Density manually. But the keyboard wasn't messed up, so I know its better. Once I get the updated build going, I'm 80% sure the build.prop should work.
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
i need help... my phone died, and now it doesnt want to charge, i plug the charger on and it does this boot loop on the lg logo...
current rom is this one btw
if your on the cannibal recovery, theres an option to fix the bootloop in the advanced menu... can you get into recovery with the key combo from the powered off state?... (home/vol up/power)
xonia has the option also...
Also. I am working in this. I just have to fix the boot loop, and make a flashable zip for taskbar at the bottom.
Reactions: topdawg661
If you boot into recovery, you can ADB flash a recovery
I had to do Nan backup and let it charge and then reflash .. this from is wonderful, its just that battery dis it boot loops also it has random reboots.
Does this have the same issue like over in the optimus s? Or is this one different?
Sent from my LS670 using Android Central Forums
I guess dude tried to port a GSM to cdma??? And the thread is dead except me and you seem to be bout the only ones ever there(just about)
That's what lurkin did. The s has the wrong build.prop in it.
pmm09
