[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
UPDATE:
H/W Acceleration is a GO! Currently testing a new build of GingerKernel with this ICS build. Angry Birds Rio runs like a champ, as does the Launcher UI. Expect a build release soon ;)
EDIT: If you would like to preview the new kernel, click here. It's unsigned, so you'll have to turn signature verification off.
In settings --> launcher --> clicking icons and dock do nothing. I hear a click, and see the touch response, but it doesn't open any menu.
UPDATE:
Drew, does this next build include other fixes besides HW acceleration?
EDIT: Also, can this kernel be flashed for the Cold as Ice ZVD rom or just for the Hydro ZVH CM9?
UPDATE:
you just flash from recovery right?
nevermind, i got it...Thanks drew!
UPDATE:
Holey moley, this is awesome. thekraven ics and now this afterburner. wow, Wow, WOW
Buckle in, sit down, hang on!
Yes
installed and so far am very impressed. data and wifi work. moving from screen to screen very fluid. youtube FC's but dont normally use it anyways. keyboard is small. i really like the htc_imod keyboard from hydro rom.
do have low memory problems....am looking forward to the next update to slim it down :D
holy crapola my S is on crack after the kernal upgrade. will it have the same side effect as a regular drug user and crash hard afterwards...lol...awesome work you guys...i wish i had the patience to do a rom...
No, it does not.
This kernel will work in both ICS ROMs, and will work in all stock-based Gingerbread ROMs too (not including CM7 yet).
Reactions: jcruckus
Building mainly for references, but I'm in a teaching mood, so ask if you want to learn.
And I'm in a learning mood. Do you have a gtalk ID I can have? I want to know what are the requirements for building a ROM. If it sounds too much to start with, I'll start with theming. I'm free for next 5 months :D
I think its awesome how the kraven and drew are the top 5 thanked members on android central...
How do I download the youtube fix that Kraven posted on the first page?
Cuz they totally deserve every cent and thank you they receive! Next to the keyboard I'm loving me some ics hehe
Honestly, data just refuses to work properly for me. Even after doing *#*#4636#*#* > Phone info > CDMA auto prl, radio on/off.
After turning off/on radio, the 3g symbol does show up next to the signal bars. however, internet pages still won't load. Wifi works though.
Try toggling airplane mode ON and OFF and then Data OFF and ON.
First toggle airplane mode on and off then data off and on also worked to get data rolling for me as well
Here is alpha2.
  • Lots of room made in this build
  • ~80 MB and you can delete Trebuchet.apk and save about 7 MB more if you like the Apex launcher included.
  • Youtube kinda works now, getting closer.
  • You will still need to flash Drew's new ICS kernel. This still has the 8.1 GK one.
  • Latest CM9 sync.
  • Sync with Beta 4 of P500 changes.
  • Using the IHO sprint apns-conf.xml. So test mms.
  • LatinIME.apk is large ~10 MB, so look on the market for a mdpi on if you need room.
  • alpha2b-thunderc-cm9.thekraven-signed.zip
  • md5 135050a97ec69576ba256f5ae1a7f07c
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
do we still need the mic fix.zip for the beta 2 build? Wow this ICS is taking over our Optimus! YES
No kidding, and that is good. I can live without camera and YouTube, so I will try to live with this for the next three days. I'll spend half that time flashing new versions, thanks to thekraven. :D
Dugoh1
