Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
I'm working on all-in-one patch, but might end up being the whole rom.
also just noticed is speaker phone broke or is there a way to make it louder?
Default CM9 music player, or Play Music? Play Music crashed for me every time I tried to stream songs, but it worked fine when I played my music offline.
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
Kraven, if going from F to G, do we need to wipe everything poor just cache?
Sent from my LS670 using Android Central Forums
Thanks, I'm still trying to figure out why it worked for some and not others. The kernel scripting mounts the system folder, then deletes the old modules and copies the new modules. If you don't mind flashing the boot.img that gave you no wifi. Then have a look at the /system/lib/module folder and see if there are the 3 modules inside. Or checksum and see if they are the same as in the zip file.
B0117F1F35D50978A8FB91C7D87E1A1C *librasdioif.ko
93FF6EE13A95B3A1BB42568E0786DDF2 *tun.ko
070EDC6677859A82762BD2B83C2E3BD6 *wireless.ko
8BA1439B4EB2888A157616938D7E2AD8 *wireless.ko
delete("/system/lib/modules/*");
delete_recursive("/system/lib/modules/")
downloading now will flash and see if I have speaker phone or if it is a cm9 issue
Google Music Force Close WORKAROUND
It's something in the /etc/hosts file that is killing it. The hosts file in these ROMs has a TON of entries in it, I'm assuming for ad blocking purposes. I pushed the hosts file from Harmonia 2 which only contains one line via ADB and it is streaming fine over Wi-Fi and 3G.
Hosts file is attached for easy access. I suppose a permanent fix would be finding out what the entries are in the hosts file that is stopping the connection, but this works for now.
Extract the zip and use a root file manager to replace the 'hosts' file with the one included in the archive in the /etc/ folder, or use ADB. "adb push hosts /etc/"
ok it works the same way as before for me the speaker phone volume is no louder than the internal speaker. tried with a fresh install of just 10F and a install of 10g both installs were full formats.
