[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
For some reason every time i try to use the cpu governor, it insta reboots my phone. I Kinda wanna put my phone up to it's full potential. Any ideas?
Unfortunately all phones and devices are not made equally. Some phones can run at 864 and some can not. Mine reboots often at 806 and less frequently reboots at 748, so i have to keep it tuned down below that. So you may just have to keep tuning it until you find a speed where your phone does not reboot.
Thanks, I set it lower and it works now.
I'm sorry if it's already been covered, I don't want to have to look though every page of the post. Is there a fix for the clock problem yet?
The clock lags still even with clock sync from my knowledge. But it does change the system time to be correct. So if you have an alarm set it WILL still go off at the predefined time. (with clocksync)
Since using Alpha10g since release I have noticed that my contacts will randomly disappear for no reason. I have to import them and they may last about two days or so.
It's a good thing I have backups, backups, backups.
As for the clock issues, I have installed Advanced Clock Widget.
This widget keeps the correct time all the time, even when there is clock drift.
Yeah, I use ClockQ widget and it's always right. If I don't want to unlock my phone, turning the screen on and off, then back on fixes it.
Any market fixes? I keep getting package file invalid
Sent from my LS-LS670 using Tapatalk 2
I have been unable to find the blacklist setting in the contacts. Any one know the location?
I don't believe there is a blacklist setting. But there is a "Send to voicemail" setting and I use Youmail, so I never really looked for the blacklist setting.
I'm not getting any clock drift only problem for me is that I wanna use Bluetooth to talk in calls!!!!
Ya, that would be nice. If I know I'll be on the phone talking for any amount of time, I'll nand over to reborn.
Sorry that won't work on this rom I had to download an app called blacklist pro. There are several similar apps you have to pick the one you like.
sent from my device using XPB ICS Tapatalk 2
For some reason, everything seems so slow now. It takes a few seconds for the phone to do essential tasks like opening up messaging, opening phone/contacts, making calls....i don't know. I put kraven's CM7.2 on my dad's phone a couple months ago, and i picked it up last night to call my phone, and everything was so much speedier. on my cm9, everything feels so labored...i'm even OC'd between 748 and 806...
(cache cleaner NG) usually works for me, updating prl, and whatever if it doesn't
Reactions: Va1ha11a
I followed this from earlier in the thread. I could install all the apps that I had trouble with (which were only google apps like drive, youtube, translate) but I still get the same error as you when trying to install google music.
Just clear playstore app data and cache, don't sign in. Then boot to recovery and clear cache and dalvik. Reboot.
nemismom
