[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
So this is where you've been lurking ;)
I'm still using cm7.2... is YouTube fixed for this rom?
If you mean High Quality, no. Qualcomm is it? Will not make the drivers. Something dumb. It would've been completed by now :(
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
Well I'm back. Havent been around for a while and I'll be due for an upgrade soon so I thought I would check out a new Rom. I've been on Kravens 7.2 for a long while. Good work Kraven!
I just installed this and love it so far, Thanks.
Will post back later. :)
Still tinkering away,
1. panoramic camera is fixed.
2. Gmail white screen maybe fixed, still testing and trying to get a blank email. 75% complete
3. Clock sync fix 25% done.
4. Test 18 kernel done, deep sleeping like a baby.
5. new alpha 17 build with the fixes 0%
Well, I just flashed the Gmail white screen fix. So far, so good!
Thanks for the great work, Kraven!
Goshdangit! Now I wish I still had my Opti S even more...
Good to see you're still at it kraven :)
Sent from my Epic 4G Touch
That's a partial fix for Gmail. The font xmls also need some work.
So it seems. I just had it happen again. For me, it appears to be closely related to memory. Every time it happens and I go to force close Gmail, my internal memory is extremely low. After I close it, I suddenly have almost half the total memory free.
Glad your still at it kraven alpha 17 will be fun I'm giving quattrimus a break and visiting my fav rom
Quattrimus seems okay, from what I've heard, but I can't bring myself to download it. This was my first ICS-based ROM and by far my favorite. :cool: Looking forward to alpha 17 when it arrives...because it will be AWESOME!!!
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 9/1 ZVD basesband Alpha17
Thanks for the awesome build! I'll install 17 when I get out of work tonight. Question: Is the Home button bug still lounging about? And if so, what's the fix for it? Is there an independently flashable fix yet? Or is it built in?
Note- I had the home bug on 16e, so I was wanting to make sure I had all the info on this before I flash. ALSO- I was hoping that wake on front button press could be disabled. I assume that fixing that would be the same as in GB? Thanks again!
New Gapps in the first post, paired with new instructions describing flashing Gapps twice, makes me wonder: do we need to have old and new Gapps packages and flash both, or is that a typo in the directions?
i think im doing something wrong? im using COT recovery and when i try to flash this, or alpha 16. it just sits at the boot screen forever, now i know they can take long but this has been like close to 15 minutes
i just hit pre-flash whipe, install rom, gapps, and the zvd to zvj patch (maybe this is the problem? i dunno) just tried it without the patch and still nothin :/
If you're coming from Quattrimus or another ROM that moves apps to an sd-ext partition, you should also go to the Mounts and Partitions section (or whatever it's called in COT now, I can't remember) and format /sd-ext. I keep asking if Drew will at least throw in an option to include that in his pre-flash wipe command . . . and I wonder if that's not keeping it from being added. :P
yea i am coming from quattrimus, and i will try that, so i whiped my boot, system, cache, and sd-ext and it is currently on the boot logo doing its thing lets see if it works...
edit: it didnt work haha. im going to see if it'll flash on my brothers phone
Possibly the same audio boot hang from alpha 16 builds that happened on a few phones. I'll have a look. I'm using cot 1.2 recovery.
Reactions: Thraeryn
so i was using cot 2.0 but i tried this all on my brothers phone, he has cot 1.2, but no ext2 partition, it booted up on his
so i put cot 1.2 back on my phone, wiped what i needed to, wiped ext partition, tried it again and it still hangs on the boot screen
so, im thinking its my partition maybe?
r3dpuk3
