[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
G'day,
In the new gapps, test_1 & test_2 is the google voice the same as google voice in the market, or is it optimized?
If optimized is there a way to just install it without the rest of the zip?
Really liking CAI, its running like a well oiled clock.
Thanks in advance, G
Those apps are from the market, you can remove what you don't like in the zip or just copy the apk to your sdcard and install it manually. Just make sure settings/security/unknown sources is checked.
Are we going to be seeing some new great updates with the ics libs from qualcomm?
That's just the egl tweak. We petitioned qualcomm back in March and those are the files they gave us.
Will the the gapps work on any ics ROMs for the optimus?
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
Do you guys know any good JellyBean themes for CM9?
I changed my LCD density to hdpi (240) using Pimp My ROM, or you can use LCD Density modder, both on the market. I prefer PMR due to all the extra tweaks and mods you can apply.
Sent from my ZombieICS-VM670 using Xparent Blue Tapatalk 2
Yea I have pmr to and all the tweaks are cool, but when you change lcd density do you change back after ?
Just tried launcher 7 on cm9. Works great. Dock4droid not so good, too touchy.
Sent from my LG-LS670 using Xparent Cyan Tapatalk 2
I'm using Launcher8 which works really well . I think the latest on Play Store is still v1.12, but there's an apk for v1.2 floating around, which has more transparency and tile size options. It's trying to deliver me an update to 1.2.2, but the package fails to install. The only complaint I have is that it commandeers the search hardware button to search apps instead of Google. (in v1.2, in v1.12 the search button did nothing). Haven't tried Launcher 7, so I don't know how they compare.
Sent from my LS670 using Android Central Forums
I changed the density to 240 and still it won't let me install the theme
I'm on VM and I just noticed I have some problems with MMS.
For some reason I can't get them from other people, but if I send one to myself it downloads with no problem.
Is there any way to fix this?
Did you flash the VM Patch?
Sent from my LG-VM670 using Xparent Blue Tapatalk 2
corneliarphillipis
