[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
@thekraven is test3 still kernel 6 + cam3?
LG-LS670 with thekraven ICS 4.04 & Tapatalk 2
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
Test 3....initial impressions, pretty much the same as test 2.
Played around with the lockscreen shortcuts, noticed that the icons don't appear, but the shortcuts work. Everything's still smooth. Haven't tested BT yet. I'll let you guys know if the audio profile bug that i mentioned earlier is still there.
EDIT: I did however notice that the notification toggles have a very subtly different appearance
Still running test 2, will upgrade to test 3 in the morning. Other than that I have nothing to report that wasn't already said. It's snappy, definitely more stable and my battery had been great. Not bothered too much by the sound routing issues since my notifications are almost always on vibrate (I did test it to make sure and it did still drop the music to the speakers during the notification tone).
theKraven: I cannot wait to install test 3 tomorrow. Sorry it took so long for me to respond with another report, I wanted to give it ample time to fully test :-)
Test 2 is great, had a couple of reboots but other than that everything is fine so far. I flashed drew's pre-4, and changed CPU governor and settings to see what that does. Test 3?
Sent from my LG Hybrid using Xparent ICS Blue Tapatalk 2
Vmfix no longer works on test 3. I believe its because of the new framework edits. Means I need to manually edit framework-Res.apk. I'm not at home right now so I'll have to do it tonight. Old framework-Res boot loops. Do not use.
Sent from my LS670 using Tapatalk 2
anyone else having play store issues on a10 3?
What kinds of issues? Play store gets flaky for me every now and then on a9 (error purchasing - even free apps, insufficient storage error when I know I have enough space, etc.). Foce close and clear data usually clears things up for me.
I was getting the 921 error message. I fixed it. had to remove my account from the phone and re-add it.
first impressions of a10t3 is battery seems to go faster went from 100% to 55% in 3 hours no more use than t2 some time period would be at about 70% didn't have either over clocked. omg does wifi fly on fb local news site ect but last few days noticed AC takes forever to load on my phone. like the new notification drop down icons. lock screen short cuts work great minus having the icons. as of yet no Gmail sync issues. will report later today with after using more.
Try manually changing the lockscreen icons to system icons or any saved images. Then click the save settings icon.
Ways I tried to fix my "Package File is Invalid" error in Google Play Store:
  • flash app cache, then reboot recovery, flash /cache and Dalvik cache
  • remove and re-add Google account
  • force close Play Store, clear app cache and data
None of them worked.
Also, they don't address the complete inability of any other method (AppBrain Market + Fast Web Installer, Titanium Backup Pro, others) to either upgrade, install, or restore applications.
My apps are frozen and I'm tired of hearing the same old methods to fix things. I'm not sure of the cause, but I think I'm going to do a clean install for a10t3 and try to restore all my apps from backups, see if it helps. Wish me luck.
Uninstall tibu pro and reinstall. Happened to me last night. You can always restore w tibu if play pen is hosed.
LG-LS670 w thekraven ROM & Tapatalk
how do you manually change the icons? replaced the camera with the default browser no image switched back to camera and no camera image.
At the lockscreen shortcut screen, get to the edit shortcut menu, click on the icon left of the application text. Remember to hit the save button. It's a cm bug displaying the icon less than 5x5
Reactions: aaronrw
awesome! system icons works GREAT thanks!
gallery images do not work fore though.
This works. you can only display system icons, and the icons only appear when you touch the lock lens.
A103 works beautifully kraven. I run Zeam Launcher with it, and it is as smooth as silk. still no bt audio however.
Also, it seems to drain battery at an alarming rate. And is VERY touchy about chargers, unless my USB port is starting to go. the phone is 13 months old.
Other then that it works awesome.
r3dpuk3
