[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
Barcodes fixed in a patch below. I only tested on goggles.
Previews seems more choppy, I'll have a look later at permissions and the code. You probably won't need all the files in the zip, but they got built with the new camera files.
For Alpha 10 test3 only. Not sure what it will do with other builds or previous alphas. More than likely it will boot loop, and you will need to wipe cache/system and reflash your rom.
Wipe cache and flash.
a10camerafix2.zip
Really choppy, but it works great on six items tested using RedLaser. Thanks.
Tested QR scanning with Obsqr. Works great. Preview is definitely laggy, but preview lag is far more tolerable for tasks like qr scanning rather than camera. Camera preview might be slightly more choppy, but not obnoxiously so.
System icons on the launcher shortcuts also look great.
HAHAH I didn't apply it to alpha9 rom firecrotch666 HAHAA i was afraid that would bootloop do to there development around the drivers area.
Short answer: Thanks, but no. Long answer detailed in that thread.
Barcode scanning: Goggles had some weird issues at first (including rebooting my phone), but after repeated poking, exiting the app and returning, etc. it works just fine. Tested it on QR codes from a few different sites.
When I tried it with previous ROMs, it screwed up my GPS so that Foursquare, Yelp, and apps other than Maps couldn't figure out the output it was sending. The "revert to stock" zip never fully worked for me, either. I had to re-flash my ROM and kernel to get GPS actually back to stock and working with all applications.
So no, thanks. Pretty sure I said all this in that thread.
My bad. Now that you mention it, I think I do remember something about that......ah well, it works for me (:
Ok heres the latest alpha test 3. It doesnt have the last camera patch.
Alpha 10 test 3. This might be close to the final alpha 10 release.
Cleaned up the ramdisk with multiple wifi permissions.
Synced to latest CM9.. now has theme support, adhoc support, lockscreen app widgets. use volume as cursors position in keyboard options.
Androidmeda cleaned up the libaudio, but I didn't see any notes of fixing bluetooth.
For VM users, this has new frameworks so the old patch won't work.
Just use quattimus ;)
No repackaging, or mirrors.
THanks to Drew, TDM, and all the testers.
alpha10c test 3
http://www.mediafire.com/download.php?3v5a8z59f11512i
alpha10c test 3
alpha10d-test3-cm9-LS670-kraven-signed.zip
so this won't work on the v at all or are you just saying the button swap won't work? the quattrimus a10 has a bug with downloading apps from the market.
alpha10c test 3
WOOT!
TiBu-ing and downloading now! Will flash this tonight and put through its paces tomorrow morning.
Are we to use the packaged kernel or is there another one we need to flash?
Many thanks to thekraven and all those that helped him.
WOOT!
Same here :) I'm also curious about the kernel...is the latest test kernel included?
Test 3 working great. I can confirm the vm button fix works. Lock screen shortcuts work but don't show.
Overall great stuff!
Kernel is already included in the rom. It's test kernel 6, if I remember correctly.
http://forums.androidcentral.com/lg...-4-5-zvd-basesband-alpha9-47.html#post1763127
Reply directly below that post.
We had a link to that test 6 kernel in the PM and I have gone back and forth between it and Drews HK01pre04 and notice no difference. I think they are the same kernel in actuality, or such a slight difference that a mere mortal cannot detect it.
Based on experience of a couple of us early testers. I'd recommend a FULL WIPE and start clean. If you restore apps with TiBu, restore app only and reenter ALL user data, system and apps.
Reactions: kbp08tls
OK can you help me please I installed a10 test 3 and I still can send mms is there a fix for that
Lock screen icons will show. Go into the lockscreen settings and when you choose an app, click on the icon to change it. Only system icons work though.
You can still use it with a special keyswap file, but sprint will be all over it.
baabazambi
