flashed stock and then to cm7, still can't get incoming calls to ring through. i'm officially giving up. i'll stick with 2.2 for awhile longer![]()
You may be on one of the captivates that can't use i9000 modems. Did you try the kb1 in the source forge? It has horrible voice quality but it should work.
Sent from my Captivate
How has everyones battery life been? I unplugged this morning around 6:30am and down below 50% by 11:30am. I've received one call, sent a few texts, and checked email a couple of times. I hadn't sent any emails, and its been in my pocket most of the day.
I'm really hoping the battery gauge just isn't accurate.
no, i didn't. i'm exhausted from it to be honest with ya. I'm running serendipity now. I'm done messing with cm7 for now. lol
thanks for all your help.
Quick update: Atinm says that the most recent builds are broken. They're still working on the merging, since the nightlies are built automatically now. Stay tuned.
another 2 questions:
1. do I need to odin?
2. I'm running serendipity 6.4, so do I need to flash another kernel, or is there one included when I flash the ROM
The new CM does not require Odin. CM requires different kernels than anything else, and their ROMs do include a kernel built in. There are also a couple custom kernels out there, but stick with stock initially. The custom CM kernels seem pretty bleeding edge (OC), and I was actually getting worse performance with them than stock, though according to posters more knowledgeable than I, the builds I was on are suspect to errors anyway, so I doubt that is normal.
EDIT- Coming back from CM will require Odin however.
when you say coming back, do you mean flashing another rom, restoring a backup of a ROM, or both?
