[ROM][FF18][July 01, 2012] DK_Liquid_Ice_v1.2.0_Stable
Status
Not open for further replies.
Try not restoring the app data this time. Were u on any ics based rom b4 this?
yeah phantom rom :o
yeah im just having an issue with my phone recognizing just let me reboot my computer and ill let you know what happened once i test it
yeah i was on phantom rom.
my computer is not recognizing my device. im going to reboot my computer ill let you know what happens.
Been runnin this Rom for a couple weeks now and it so much better than stock!! Thank you much DK. I am havin one issue tho.....I can't change my ringtone or notification sounds. When I go check it says it's using my new sounds but its not. Any advice would be greatly appreciated!!
Sent from my SPH-D710 using Tapatalk 2
Its using cm9 sounds. You have to modify the build.prop with the sound of your choice.
Reactions: elport
Ok....can root explorer be used to find that. I've rooted before but yours is the first Rom I've flashed so still extremely noobish lol. I appreciate your work and your help!!
Yes you can use root explorer
Attention: This is a Data Speed Fix. ONLY USE THIS PATCH IF YOU GET HORRIBLE DATA SPEEDS. MY ROM INCLUDES SPEED TWEAKS BUT IT MAY AFFECT SPEEDS NEGATIVELY IN SOME PARTS OF THE COUNTRY.
Directions To Install:
Download Data Patch
Boot into My Recovery
Wipe Cache
Wipe Dalvik
Flash The Patch
Reboot
Download DK_Liquid_Ice_Data_Patch: Download Data Patch Here
Hey there, followed the instructions to a T and I suspect I am one of those with extremely poor 3G speeds on this ROM. WiFi and 4G seem to be working as normal. The link to the tweak above is no longer working. Do you still have this file somewhere?
Thanks!
Do you still want catlogs after crashes.
Sent from my SPH-D710 using Android Central Forums
Correction: it's 4G speeds that are something so absurd it can't be right--around 30kbps down and up according to Speedtest. 3G sounds plausible at around 500kbps down/300, so that seems to be working fine. Wifi to my wideband cable connection shows my typical ~15Mbps down/5 up, so it really does seem to come down to the 4G data speeds. Otherwise everything seems to be doing okay.
Just wanted to say thanks for the work. I played around with this ROM for awhile until I had touchscreen issues. [ not your doing ] worked very well, I just sent the phone in for repair. Hope to try out the AOKP next.
Reactions: Dark_Knight2
Status
Been0121
