[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
@ThatGuyLurkin
You port cm7 based roms
Zvj has no cm7 so one question
Would it be possible to port a rom like this but base off OFFICIAL GINGERBREAD would it work
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
I would say No, buy i say give it ago. Drew was talking about ZVJ lib Files, so im thinking what if you try to use those libs for CM7. Or what about the ZVJ libs from CM10
Sent from my LG-VM670
Reactions: StingDrop
What fixes? CM7 is perfect. No bugs, apart from that headphone thing.
You may want to fix the problem were wen u type sum on the internet or YouTube it dissapears plz and thank you.
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
Thats not even on this rom. Not even a bug. But yes. Ill tell you what to do.
Use Root Explorer or Titanium Backu.
Uninstall System.apk
Install a non transparent theme
Problem solved. :) I believe your talking about GTR though
You efff my phone up !!!!!!!!!!!!>:( hahahaaahahaha jk
Will do this soon
If this works i think people will be more obligated to build/port for zvj
Not that simple, otherwise it would've been done already.
1: No idea which libs
2: Not even sure it's the libs
Im confused. ZVH roms work on ZVJ with no problems
That will help me about. My wife's phone is in zvj but she doesn't like her Rom and won't let me downgrade. Now I know I can just flash a zvh Rom, thanks
In open it says beats audio and braiva hacks are installed but I can't find settings for them are they still there and just always enabled or something else? Btw I updated from gtr port
Afaik they are always on
Originally Posted by ThatGuyLurkin<br />
Im confused. ZVH roms work on ZVJ with no problems<br />
<br />
<br />
<br />
That will help me about. My wife's phone is in zvj but she doesn't like her Rom and won't let me downgrade. Now I know I can just flash a zvh Rom, thanks<br />
<br />
I meant Does it work! I'm sorry. :)
Sent from my Triumph using Tapatalk 2
Pnonsgiti
