ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1 - 9/16/11 - GB 2.3.3 [Official!] It just got r
Both of you look at my FAQ. Its post 2, question 2. I'm on my phone right now so you will have to search. Or click my name, go to 'view public profile', click on 'threads started by...' and the title has [FAQ] at the beginning of the title.
EDIT: Also let us know if it helps or not. People are reporting workarounds all the time so it would help if you guys give everyone some feedback too! :)
heres your thread: http://forums.androidcentral.com/lg...p-general-roms-rooting-related-questions.html
but the debug download link is broken =(
a dirty flash a few hours after installing gROM got rid of the laggy-ness for me. doing great now.
just tried basketthis's method and still got lag. was i suppost to also update the prl?
and what's a dirty flash?
could you take out the feature "Ad Blocking"? if you can upload that ROM or is there a way i can safely remove it... please let me know ASAP before i download + install :)
why would you want to see ads?
lol why not xP
well basically im doing this for my little cousin and well unfortunately he CHEATS!!! he uses GameCIH and with out ads he wont be able to use the application lol im not doing this for my health xP
There is a thread here (and a few others in the parent section of this forum) about gingerbread issues. It seems the update did more damage than it improved on for most...
http://forums.androidcentral.com/sp...own-gingerbread-2-3-3-issues.html#post1282586
Like I said, check the other threads to. As what most of you are experiencing is gingerbread related and not the rom itself causing the issues...
EDIT: However it is important to have this discussion in this thread too. (Just want to make sure that I'm not giving anyone the impression that they shouldn't post in here, etc...)
is no one going to help me!?!:mad:
Most ad-blocking apps modify the hosts file so it redirects to localhost when an IP or a range of IPs are accessed.
Try to use the following thread to find the hosts file and remove the entries added by the blocking script:
Where is the Hosts File in Android? - xda-developers
Good luck.
edit: the only line that it should have is "127.0.0.1 localhost"
Reactions: reltm
http://scottcrosler.info/
403 Forbidden
You don't have permission to access / on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache Server at scottcrosler.info Port 80
Cant download!!!
403 Forbidden
Cant download!!!
Same results for me. :'(
And I was ready to take the ZVH/ GB plunge!!!
im at the ZVH GB Rooted but w/custom recovery but no custom rom!!! wtf?!
Calm down man! I will attache a flash-able ZIP in about 10 minutes to enable ads.
403 Forbidden
Cant download!!!
Site moved! Go to Scott's ROMS - Home!
Reactions: harsho1
No ad blocking host file has been added to post #2.
Not tested but should work just fine.
Flash in recovery like any other zip.
Hit thanks!
Reactions: srthimsen
I've been running Grom since it was available and have only had the problem of a very touchy screen but that was only with ginger kernal. once i did a dirty flash to get back to the stock kernal i havent had any problems at all and i'm very happy with my deciion to update. i just hope we get the ability to oc soon thats really the only thing i miss. great work and thanks to everyone involed on this project. also the themes available are great too so make sure you guys look into those as well.:)
Reactions: scrosler
Glad you enjoy!
Really like the rom but I hate the new gb update. Will be coming back to this once gb update is alittle more stable and when am oc'ed kernal becomes available until then reverting back to use drew's cm7..
Keep up the good work devs
So in order to go back to cm7 I have to revert to zvd?
Status
BOb_marley
