Re: [ROM] - gROM 2.1 - 10/8 - GB - OC'ed - Infinite Possibilities
I'd be willing to try that patch for the screen sensitivity before reverting back to the zvd radio. Mine is really bad and is making my phone unusable because it's so frustrating. Typing is bad enough, but long pressing and dragging things around is impossible.
			The screen sensitivity can also be attributed to the kernel and possibly a tweak I did but I don't think the tweak would cause that. I can make a patch if you are willing to test it. But I am thinking its more of a kernel issue. Not sure 100% though.
A lot of issues people see with the stock ZVH update I dont see. Some see them some dont. For example, my phone charges perfect on USB, just like Mikes. Some people cant. Why? IDK! lol
As far as Apps2sd I will incorp that in the next ROM although... I don't like the idea of it... I will make two versions. One with and one without.
I'm working on my main device and work on this one when I bored with the 3D so you wont see another update prolly until at least this weekend. Not sure. Just take it as it comes.
-Scott
