[ROM] Harmonia 1.87 Froyo (Aphrodite+Picasticks) 12June12
Re: [ROM] Harmonia 1.5E (Aphrodite+Picasticks) 10AUG11 Edify FIxe
It uses fat32. It has to be done through your pc. Recovery only does ext3. I use mini tool partition wizard on my pc. It also has to be reformatted through the pc when you flash a new rom.
Took me a little bit to figure out. Link2sd seems to be a bad word for some reason. I've had a couple issues but 99% of the time it works great. Now if it would link data files too I'd be happy.
I have always used RA-thunderc-v-1.2.0-GNM recovery and have used many ROMs both 2.2 and 2.3 I tried to flash Harmonia 1.5E and got an error with the file path with (bad) after. It did the same with and without signature verify. MD5 checked out
Strange since it works in IHO recovery.
For some reason you lose link2sd app on the flash to 1.5e, just redownload, load the app, select fat32, it will tell you to restart, do so and when you reboot all your linked apps will be back. Some widgets will have to be resetup.
Edit: if you replace swype with the new version of swype and use link2sd make sure not to link it which It will if set on auto link. On reboot with this rom it will force close if linked. If it does happen just unlink and you will be gravy.
Guys I have a problem. I installed Harmonia from ThunderC recovery. Now when i boot up the phone, it just sits on the second Harmonia logo and stays there. Its still moving cause I can see the flow scroll across the letters, but it won't fully boot up. Any help?
That means Framework locked up, re-flash. You may have to download a fresh copy.
It can take a minute or two to get past this the first time it boots as well, but if your boot takes more than 5 minutes or so, something is wrong.
See, thats the thing. I cant boot up to allow USB Storage transfer so i cant add it to my sd card D:
Not even though recovery? Through cwm i go to mounts and select the usb mounto or you can buy a sd adapter for your pc
So restore your last install, download a new copy straight to the phone and use a tool to verify the md5.
Or even just try re-flashing.
Oh. I just decided to restore an old backup I had. I might try it again later.
Replacement Parts (Now in Edify unless specified!!!)
Things removed that you may want to put back
Unless specified, these are placed back in the system area, saving space for you to install other apps. Flash these through Recovery, but expect a slow first boot after. Be sure to boot into Harmonia at least once before flashing these. Maps_5.8_patch.zip Aug. 2011 (Uninstall any Maps updates before flashing) Other Language Files Sounds and ringtones Alternate sounds (Same as above, but meant for you to extract to your SDcard instead)
Options!!!
LauncherPro Dock files
These are meant for use with LauncherPro, which is a free dock available in the Market. LauncherPro Dock theme The file includes Manup456's Clean (white) and dirty (black) Minimal Text icons, Orbz II center icon by H0CKEY, the bar (with button options). I included some variations of it. One has the bar higher or lower, another has shadows for each button. Another has a shadow for the bar. I don't claim credit for those other bits, I included them only for simplicity. The stainless bar and button options are mine however.
Statusbar Options:
Harmonia 1.3+ and Bumblebee 1.9+ ONLY, for older versions see below
Be sure to boot into Harmonia at least once before flashing these. Flash these through recovery, just like a rom. You can flash one on top of the other without wiping or anything but expect a slow boot the first time, just like when you flashed the rom. Black status bars Gray status bars (Flash this to return to stock) Framirezferrer's black bars will also work on this rom.
Older/other status bars (Harmonia 1.2 and earlier, Bumblebee 1.8 and earlier, all Aphrodite and Stock + Xionia)
(My thanks to Takenover83 for his help with these.) Be sure to boot into Harmonia at least once before flashing these. (These are NOT Edify!) Flash these through recovery, just like a rom. You can flash one on top of the other without wiping or anything but expect a slow boot the first time, just like when you flashed the rom.. Black status bars Gray status bars (Flash this to return to stock)
Changelog:
1.0 initial release 23Apr11
1.0.1 released 24Apr11 (removed)
1.1 released 26Apr11 wifi/Battery fix
1.1.1 patch released 26Apr11 fixes geolocation based force close.
1.2 released 6may11, MVDalvik, Init.D, and possible improvements to bluetooth.
1.3 released 17June11 TWS, reboot menu, updated a few programs, minor tweaks here and there.
18june11 Added H.1.3 statusbar options and corrected minor graphical bugs in them, added links to various other applicable guides.
03July11 changed layout
1.3.1 16July11 Update adds email and MMS from 2.2.2 and new Market app. Also new Maps v5.7
9aug11 Harmonia 1.5 released, changed installer to Edify for universal installation. gave up on the new market for now. Added new maps to options.
10Aug11 Harmonia 1.5E Edify released with corrected V.15 Edify.
Previous versions:
Harmonia 1.5 Edify installer BAD!
MD5: 64819df805b02822aa0bcd26b8c4edbc
Harmonia 1.3
MD5: ffcc96637995a5f45027f2c8cf1797ee
Harmonia 1.3.1 patch
MD5: 41eab570e10116cff704f489f6255822
Harmonia1.2.zip
MD5: 1e53fd8eea6ca28a8f87a298f858347b
1.1.1 patch fixes a few programs force closing (Yelp! being one of them).
Harmonia 1.1 to 1.1.1 Patch
Harmonia 1.1
MD5: 374beccefc7e4c63a496cf1f6152d947
Harmonia 1.0
MD5: 46fdde6f41d0f4beb9720ada22166284
silly question...when i flash the status bar zip file, nothing happens. the status bar stays the same. am i doing something wrong? lol
Which one are you flashing, there's 6 of them.
Hey leslie, I'm curious are you planning on jumping the gun when the optimus black comes our way? I appreciate the support on our Optimus Vs. I know you were hesitant to jump on the triumph bandwagon, Im just a lil worried about support freezing up on our lil LG optimus anytime soon
I do plan on going to the Black when it comes out, but that could be anywhere from one to 4 months and it's not like the rom will suddenly stop working.
Even when I switch, I probably won't just disappear, but I can tell you that more than a few OV devs plan on switching when it comes out. There will be a flurry of activity right from the get-go, especially since so many carriers are all getting the exact same phone. In all likelihood, it may become one of the best supported phones out.
The "Harmonia 1.3+ and Bumblebee 1.9+ ONLY" grey status bar version :)
edit: i figured it out, but mine doesnt look like the above pics. lol. the only thing thats changed on mine is the signal meter
Uhh I'm pretty sure the signal meter is stock on all bars
The only changed on them is the battery icon and/or color. That is all.
Something failed.
aravrajak
