kiellsdroid
- Jan 27, 2012
- 6
- 0
- 0
Hi Sam,Can anyone please tell me how to activate the optimus v with Harmonia 2 installed. I have recently got my optimus v. I activated it, rooted it, and flashed Harmonia 2 to it. Now I want to port my Verizon number to my new optimus v. Virgin Mobile basically disconnect my phone and want to reactive it again. So when I tried dial "##478446#" the menu doesn't come up. I searched other forum and learned that Harmonia can activate the phone. Please help!
I have not tried this myself, but I've seen many posts about it. I believe since Harmonia 1.7 is actually based on the stock ROM, that you should be able to use any of the activation features of the phone as delivered by VMU.Hi Dan,
Thank you for the quick reply. Unfortunately I didn't backup my original stock rom. I did backup my current rom. I will try to flash Harmonia 1.7 to my phone. Btw, once I successful flash Harmonia 1.7 to my phone will I be able to activate my phone using the '##478446#" method, or it is a different procedure to activate it?
My wife also has the optimus v (we bought the two phones at the same time) and has nothing been done to it (i.e. still has the original recovery and stock rom). If I fail with activiating using Harmonia 1.7, will I be able to utilize my wife's phone (such as install the same custom recovery her phone, do a backup to a sdcard, then insert the sdcard to my phone and do a restore? I know this is probably a very unique situation and no one has probably try it before. But I would like to explore all options.
Thank you.
Sam
No sucess at flashing Harmonia 1.7 here. I use CWM 3.0.0.6 recovery and flash Harmonia 1.7. I did a full wipe as the following:
Select ?wipe data/factory reset
Select ?yes?
Go to ?mounts and storage?
Select ?format /boot?
Select ?yes?
Select ?format /system?
Select ?yes?
Back out of that menu to the main one again and select ?advanced?
Select ?Wipe Dalvik Cache?
Select ?yes?
I then flash the Harmonia zip file. Everything went fine except when I rebooted the phone only the LG logo flashed by and went away and it stucked at a blank screen.
I'm using cwmr too and all I do when I install roms is the factory reset and dalvik cache wipe, those two work fine for me. Try just wiping those two and then flash andsee if it boots.
Load up 1.7 and hit activate, everything should happen automatically.
And yes, the ## thing works, but all you need is to hit Activate. If it doesn't complete, try again, it can take 2 or 3 times to finish. Once done, go back to CM7.
Edit:
You are not getting a good flash, which is a problem on the newer phones.
Md5 the file on the sdcard, and make sure you wipe system, boot, cache, data and Dalvik at least once.
The Bobzhome IHO recovery may also help. Guides to all of this are at the bottom of post 1 in Harmonia 2.
Doesn't count.I MD5 the file on my pc and it's fine.
I was gonna suggest exactly that. That's a pretty old recovery you have now.LOL, I guess I could restore to one of my backup and I could then MD5 the file and flash new recovery. A little slow here.![]()
Sounds like a stubborn phone.
