[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
Re: [ROM] Harmonia 2 (IHO Gingerbread) See first post for updat
Selecting Power off with the top button seems to reboot the phone instead of shutting it down. Haven't found any other bugs yet.
Are you attempting this while the phone is plugged into a computer or charger? The phone cannot turn off while charging on Gingerbread based ROMs at this time, though we may have a fix in the works (no promises).
Reactions: aldamon
On UOT, use "upload files", not "CM7 theme", which is probably why the icons are staying after you guys try changing themes. You only need to upload framework-res.apk and SystemUI.apk.
Hello, I was hoping to get some help. I flashed the Xionia recovery mod just fine, but when I start installing Harmonia 2 it just hangs at the 'Harmonia' loading screen after a while. Am I missing something.
Yup, that's it. Thanks for the heads up.
@Fstmstngs I encountered the same problem, because some of the icons just wouldn't change, I took apart some .apks and the icons are housed in SystemUI.apk which can be seen by pulling that file from /system/app and replacing the icons you want. I messed up doing that tho so I switched to BACKside because its bar icons were all stock. @LeslieAnn why are some of your icons not stock, and should they change with theme Chooser, because I couldn't get them to change except manually.
Sorry, Leslieann just said what I said, my bad
Battery icon with percentage has no vertical green bar next to it. Just two little horizontal grey lines. Is this normal? On BACKside and BobZhome the green bar is there.
Harmonia screenshot...
Sent via VM670
I had the same thing on Harmonia2. Its fixable if you find the battery icons in the framework-res or systemUI like LeslieAnn suggests doing in UOT kitchen, although its possible to do it without using the kitchen.
Reactions: montenell
Well on mine My battery bar is showing as well as the %, great rom.. amazing battery life.
If it helps at all, the gingerblur themes display the correct battery icon.
-Mike
Sent from my VM670 using Tapatalk
You've done it again LeslieAnn, thanks for this great ROM!
[/URL]
Sent via VM670
The first post shows the battery icon, if you are seeing something different then you had a bad flash.
Are you sure? If I go:
Menu -> Settings -> CyanogenMod settings -> Interface -> Status bar tweaks -> Battery status style and set it to "Percentage" I get an icon like Ticojpunk described as well.
I can get the icon shown is post number one just fine. If I change to the other style in the CyanogenMod settings then I get what I posted.
Sent via VM670
Thanks LeslieAnn I love this ROM! How can I get updates from this? (:
I can't guarantee anything once you start making changes.
An update will be coming soon, but for the most part, it seems to run well.
I can confirm this as well.
Reactions: rmm1962
What do you mean "making changes"? These are just standard CyanogenMod settings. Is that not clear? I'm not "theme-ing" or anything like that, these settings are built in. This is like saying I can't add any accounts to the phone to me or I can't change the ringtone, so I think I'm misunderstanding what you mean.
Don't worry about the color of the tiny battery, why would you want to focus your eyes on that min battery when you can use the default battery wish also has %+battery that comes with this Great Rom:)
Originally Posted by OptimusVdarwinn: Thanks LeslieAnn I love this ROM! How can I get updates from this? (: An update will be coming soon, but for the most part, it seems to run well.
@@@@@@LeslieAnn is there any way you could add the custom text carrier in your next update/or future, :) if not do you know how I could add it to your rom/if possible
Great Rom!!! Thanks
Takyi Benedict
