[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
I actually made a lengthy post in the IHO thread this weekend (see here) on the subject of that Bluetooth bug, including some things I have tried to change my BT address (unsuccessfully so far).
I am hoping to engage some of the devs in fixing it.
Re: [ROM] Harmonia 2.07 6May12 (IHO Gingerbread)
Yeah, I don't think there is any harm in posting the entire address (especially since we all have the same one, unfortunately, but mostly because we'll never be in close proximity)
I just remembered it started with 43 and ended with 00. Been like this since the beginning I suppose.
I'm currently running a Harmonia Froyo variant to get around this bug.
I'd love to switch back to an IHO Gingerbread rom , but this is the only thing holding me back. (two OVs connect to my car BT)
Dannemand, 'bout to check out your thread. Thanks. I unsuccessfully tried some ways to change the address too a couple months back.
Reactions: Dannemand
@Schlidel: I remember, I actually refer and link to your original thread in that post of mine.
I suggest you pitch in in the IHO thread, so they know there is interest in this. Thanks :)
Done.
I wonder where in development this problem crops up. Best to leave them the note, but I hardly understand the dev hierarchy. IHO? Cyanogen?
Does IHO port CM? Then others get it last in line to make further mods before it reaches us? Quite ignorant on the hierarchy.
OK, so I've been trying out Quattrimus in alpha. Prior to it I had been using Harmonia 2.03 I see now there has been a new release. If I wanted to update to 2.07 from 2.03, can I pull up my nandroid backup of 2.03 and flash 2.07 over it? Thanks.
I think so, wipe cache and dalvik cache though. If you have problems just do a full wipe. No biggie :D
Tapatalkin' from my Harmonious HoneyCombSandwich
Reactions: Garymeister
Done.
Yep I'm no dev either so ditto on that.. Just a lowly user who prays on the ROM's available.. I ASSume that IHO means I hate orgasims but that's just me as I have inferior human organs..
Is there an alternate apk for voice search? It seems to be the only preinstalled app not working in 2.07 when connected. Actually, is there a site for replacement stock apps just in case? Thanks again
2.07 should be pulled or at least a note about incompatibility issues with many apps. Harmonia releases are usually very good and do not need anything else, like 2.07 needs gapps and market fix for many. Just my two cents, I am back to 2.06 which has been a better version all around for me, splash screens are better too.
You should be able to get everything from Google Play. Delete Voice Search using Titanium Backup and install it from Play, it might solve your problem.
The problem you guys could be having is a bad titanium restore or bad wipe. I've been on 2.07 for a week and haven't had a single problem now. Play works. Voice works. Everything works, runs and is stable
For what it's worth, I'm a first-time user of the ROM, and did a complete wipe of my phone before installing it, without any sort of backup-restoring. And I have the incompatible-apps issue.
I think LeslieAnn is planning to rebuild the next Gapps release, which should happen this week. That'll probably take care of the issue across the board. I'm hanging out with 2.06 until then. Slick and flawless.
kevin_bkt
