[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
Re: [ROM] Harmonia 2.07 6May12 (IHO Gingerbread)
I just tried these same apps on version 2.06 and they show up in the market and poynt even installed without problems. I was just curious. lol
For me, it was HeyTell and MyTracks, both of them apps that require Maps. Coincidence? Yeah, probably.
I had problems with heytell as described in message 1020.
Go to mobile.brothersoft.com/heytell-69659.html and click compatible devices. The OV is not supported but other Optimus (IDENTICAL) phones are supported. This must have changed recently because my wife has used Heytell on OV for a year.
2.08 is updated
Based on Mirage dated 15may12
Voice search and app compatibility fixed
Can we still use the wipe cache, system, boot, and dalvik method for updating?
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
Re: [ROM] Harmonia 2.08 19May12 (IHO Gingerbread)
Confirm fixed. I tried with Bank of America's app, which had previously shown as incompatible. It just finished installing successfully.
Thank you Leslie Ann, voicesearch works wonderfully now. "Podkicker free" still says cannot install in my device's country, but "podkicker pro" shows up in the market. Im not too worried about this app as there are many like it. I checked some apps that were problems for other people, like "yelp" and "Heytell," no problems.
It could be my imagination but 2.08 seems faster than 2.03. Been using your ROMs for over a year and have been very happy with them.
I would think it should run better in ways, if it's based off Mirage's latest build then it includes CM7.2 rc2.
It should, but as always, it;s best to start fresh to avoid issues.
Podkicker may have setup some limits. Glad the rest works though.
Not sure about it being faster, but compared to 2.03? Yeah it might..
He updated from 2.03, which is quite a jump.
2.08 is updated
Geesh, LeslieAnn never fails to come through. That's awesome. NOW what will we talk about?
Thanks, LA.
Wow. This is why I shouldn't do geek stuff at 3 a.m. Got excited about the new version and went right for it. Booted into recovery and cleared cache, system and boot. Then I realized I hadn't downloaded the 2.08 zip file onto my SD card. So I went back a screen and rebooted. Blue screen of death followed, with a bunch of gibberish. Pulled the battery and tried again. Same thing. Horror! Fortunately, using the button sequence to reboot into recovery worked just fine. Restoring from the backup (I made that just before clearing cache, etc.) as we speak. I'm a dolt. Still not sure what went wrong, though.
but i just got my .07 install done... lol... (first time using Harmonia)... thank you miss!... :-)
2.08 is updated
LeslieAnn,
thanks again for your excellent work! Went from 2.03 to 2.07 and now 2.08 without a single glitch, perfect load every time, everything works great!
I have searched this thread for donation links, but can't find any. Is there a way to make donations to support your work?
2.08 is great, all the "incompatible" apps work now, but contact sync doesnt. To fix it i used root browser and copied accountandsyncsettings.apk and googlecontactsyncadapter.apk (something like that) from harmonia 2.07, copied them to system/app and changed the permissions, rebooted and all is well:D
Leslie Ann? Is Mediafire down, every time I click on download, it sends me to a blank webpage....
What exactly was updated in 2.08? I'm curious, I don't want to update if I have no need lol.
I added a donate button next to the download link.
Both of those files are there in the rom, my guess is that you had a bad flash. I would flash over your current install (backup first and after doing an md5) because if that is corrupted, who knows what else is.
dunalfu2
