[ROM][ICS] Pete Alfonso's Nightlies
Yeah try a dirty install, yesterday I went to edit an existing calendar event it would cause a soft reboot. I dirty install of the ROM cured it.
anyone know if there is a way to turn off the google search bar at the top? you can get rid of it on some of the other roms, but I haven't found an option for this one.
You can use a 3rd party launcher like Nova which has the option to remove the Google Search bar.
Reactions: erjent
are you guys able to upload to picasa from the gallery? I'm having no luck. Or do I need to now do it through G+ upload?
Has anyone been running into random resets lately? This rom has been solid just recently weird restarts.
Not the end of the world just random.
I feel with any ROM eventually they just get gummed up with garbage and need a clearing every now and then. Could be just the dalvik cache loading up and other things but I find even the most solid performers out there after a period of time end up with a few random reboots or the need for a cache and dalvik cache wipe and re flashing. Same thing happened on my previous device.
I posted this question earlier on another forum, not sure if anyone is still watching that or not. So I will ask it here. I updated my nexus s 4g with the leaked ICS 4.0.4 odin files and it worked, but I am having too many issues with it, and I would like to go back to the stock gingerbread until the official ICS OTA comes out. I am not rooted, and do not want to go through that process. How do I return to stock from ICS to gingerbread on a non-rooted phone, please help I have searched everywhere for this info. Thank you!
The changelog indicates Use my wpa supplicant 8 repo, wallet and books updates, fix sync toggle, pulse low battery light switch, don't enable light sensor if its not being used, unlinking of notification sound and rigtone volume, and add national data roaming and make it optional, whatever all this means :)
GPS doesn't seem to be working quite right. i used it twice yesterday, first time it couldn't locate the actual location very well, 2nd time, i missed my exit, and the GPS kept rerouting the address, but never locked a new route. anybody having his issue ?
Haven't used GPS in a while. I will try using it on the way home and let you know if anything funky happens. I will take different exit to see if it reroutes me. Can't get lost going home from work. lol
kingteekay
