[ROM][ICS] Pete Alfonso's Nightlies
Dammit. Just kidding. Weirdness that he didn't post this on his twitter account. Looks like tomorrow morning I will be uploading the new rom. Has some good stuff in there. Display contact pictures for mms.
Sent from my Nexus S 4G
Looks good. I like how you can add contact pictures to text messages finally. They showed this off when ICS was first shown. Its about time.
One of you loyal Bugless Pete fans like to post a recent change log ? I know I'm being lazy for a change :p
[INFO]Changelog as of 3/18/12
Ice Cream Sandwich Changelog[/INFO]
  • Common: Android 4.0.3 via stable release branch
  • Common: Deodexed, rooted, "user" build variant
  • Common: Hide "System updates" preference
  • Common: Enable adb debugging by default
  • Common: Disable data roaming by default
  • Common: Add additional live wallpapers
  • Common: Add various bug fixes from CyanogenMod
  • Common: Add build date to "About" screen
  • Common: Remove bugmailer from user builds
  • Common: Add extended power menu (dvtonder)
  • Common: Allow 180 degree rotation
  • Common: Disable kernel debugging, update by merging remotes
  • Common: Add "Mark All Messages As Read" button to Email app (dustinmj)
  • Common: Enable more keyboard keys for larger screens (cyanogen)
  • Common: Add auto-dim backlight setting (solarnz)
  • Common: Add CPU Settings to "Developer options" (cyanogenmod)
  • Common: Add status bar toggles and settings (aokp)
  • Common: Enable unlinking of ringtone and notification sound (aokp)
  • Common: Add national data roaming setting (rdlgrmpf, lord clockan)
  • Common: Add browser user agent selection setting
  • Common: Add browser option to open link in incognito tab (danesh)
  • Common (Tablets): Add auto-hide status bar setting (flemmard)
  • Common (Tablets): Add home button to browser toolbar
  • Common (Tablets): Move status bar clock to the right, fix padding
  • Common (Tablets): Hide mobile signal icons when connected to Wi-Fi (solarnz)
  • Stingray/Wingray: Add USB host support
  • Stingray/Wingray: Enable dock settings
  • Toro/Maguro/Crespo/Crespo4G​
    : Add Google Wallet application
  • Toro/Maguro/Crespo/Crespo4G: Add "Nexus" notification sound
  • Toro: Increase battery capacity from 1750 to 1850
  • Toro: Allow use of native tethering for free
  • Toro: Remove Verizon applications and libraries
  • Crespo/Crespo4G/Stingray/Wingray: Add Face Lock security feature
  • Crespo/Crespo4G: Add Touch To Focus camera feature
    (havlenapetr)​
Here is what I can see.
Revert "Added/Changed the labels for USB Storage to reflect USB storage instead of SD card"
new kernel prebuilt
Fix bootloop issue when plugged in
Allow no media notification to be dismissed
Increase system partition size
Settings - Fix Google typo in utility function
Remove the no media notification
When disconnecting external storage on Xoom, this
notification would appear and was not able to be
dismissed. There is no need for this notification.
Update Market, Maps, Music, Books, & Videos apps
Books V. 2.3.5
Movies V. 1.4.9
Music V. 4.1.513
Market V. 3.4.6
Maps V. 6.4.0
fix alignment of add number of toggles in toggle layout.
Added a spacer if uneven number of toggles.
Add sanity check for battery capacity range
Increase min brightness as per request[/QUOTE]
I've had this rom since about late feburary.... haven't updated it since I first got it.... do i just install the update to my sdcard like at first or do I need to do something different. Still trying to learn all the basics of ROMs and what not :confused:
Copy the zip file to the sdcard.
Reboot into recovery.
do a dirty flash (wipe cache and dalvick).
then install zip from sdcard
Enjoy.
Reactions: Funkad
I'm having some weird signal issues. Anytime my phone leaves a wifi network it takes an exceptionally long time before it will hook up to Sprint's network, if it hooks up at all. I'm not sure if this is a radio issue or something i need to change in settings. Anyone have any suggestions for a fix? Or is this just a bad hardware/software match? Sorry if this has been brought up before, i tried searching to see if anyone else is having the same issue but to no avail. I switch back to Peter's GB Rom and I never have any such issues.
saujanya
