[ROM][ICS] Pete Alfonso's Nightlies
I think it would be sweet if instead of turning lock screen unlock button would turn blue instead of white.
That would be a cool options. I got my signal issuses worked out. I just reflashed the new nightly.
Everything seems back to normal. Strange.
Hey. do any of your guys know if you can reflash an older nightly? This current one is acting weird for me.
I have reflashed and wiped cache and davilk too. I thinking maybe I should do a full wipe and reinstall? Any thoughts?
Still having signal issues?
I think the signal issues are gone now. Thank god. I just feel like my phone is draining faster than normal. So I am going to run the battery down and see if that helps. For the most part my battery life on Peters ROM has been aweseome. I still swear by Peter's ROM. I enjoy everything about it. Being in Chicago our sprint signal has been horrible for the last few months. Due to over congested lines.
I don't know if its the rom or the kernel but every now and them on my home screens I will see a flash of something.
Scratch that, I turned off 2D hardware acceleration.
I had that problem also. Not sure if its a know bug or not. Knock on wood I haven't had that problem in while. Since the early builds.
Everything is been working good so far except battery life. For whatever reason, the battery is not lasting as it used to, before version 02/09, battery will last 21-23 hours, now, that's down to 15 hours. anybody noticed the same behavior ?
I agree. Battery life has gone down for me with latest 2/9 build. I have it on the interactive setting, which I presume is how it was before 2/9 build (even though this latest build, if I recall correctly, gave us option to change CPU settings).
I've also noticed that coming out of wifi, sometimes the phone has trouble switching back to 3G network. I have the latest radio flashed, too.
After I reset the battery status Im back to over 24 hrs or so. I turned off 3d rendering in apps.
Try a battery wipe. See if that helps
TrueAlpha
