[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
you should think ya self lucky i have no 3g sign at all even though im in a 3g area at home. nothing is displayed at the top just a grey box i dont have an internet signal bar look at my screenshot is yours like this. can someone please upload what theres is like because i have no 3g bar at all even though im connected to a 3g area!!!
Whats weird is I rebooted now its normal size haha
For everyone who wants the galnex theme I will be digging around beezy's to see what I can do. Hopefully I'll have a patch to make it more ics like for all you ungrateful people
This takes care of everything except lockscreen clock, I'll look into that. I know there are other ways of installing the font, maybe one of them gets the clock as well.
You could also drop the fonts directly into the install zip before flashing (using 7zip : /system/fonts/
hey there beezy. you never dropped me a line to help with the port lol but in the stage its in i dont know much of what i could contribute other than making it faster and more efficient. one thing i can do and can do very well is create a kernel made specifically for this rom. would you mind telling me if your kernel is the stock one or an older one or what. i can pull whatever source your kernel came from and make this puppy wayyy faster and wayyyy better on battery cus it drains pretty quick. pls respond on here or drop me a pm and we can gtalk later and figure out some more fixes and fix some stuff with the kernel and whatnot. get back at me :)
I could be wrong here (don't see it on the OP anymore) but I remember beezy saying he was using Pete's Kernel at one time.... Not sure if it's in this current build or not??
Others have posted issues trying to use Matrix 9.5 that I saw and I think Trinity was a no go as well on this too??
by the looks of this rom this isn't an SDK port..? looks much closer to the earlier build of ICS that was found on a Nexus S. Correct me if I'm wrong
either way amazing job wish I could run this on my Inc2! :cool:
- DiGi
Can't wait for this.
Hero its been awhile, hope all is well.
Would love a kernel that takes advantage of voodoo color app, BLN, and the normal assortment of stuff like over clocking and under volting.
Sent from my Nexus S 4G using Tapatalk
what are the chances of us getting a beta3 beezy, to be honest there isnt much else you can work on is there lol.
I just think its funny how small the 3g icon is lol....What is the cause of that?
They changed the sizes of the icons in ICS.... They are close to Froyo/GB in size but a bit smaller/shaved off....
I see in the OP that WIFI isn't working.. Mine IS working, at least connecting to a mac filtered linksys router. IP address and all.
NFC won't turn on. Data gets stuck on 1x till switch to WIFI and back.
No reboots. Smooth interface. Menu button works just about everywhere 'cept on the home screen -that I've noticed.
Thanks for the hours of Ice Cream Sandwich fun!
Wifi works for me but I can't change my keyboard. When I long press on a input box I can't change the keyboard type
Sent via Tapatalk using a Nexus S 4G with CM7
so ... I know its still early in the refining process but is there a way to get superuser back? So I can make a nandroid with ron manager??
Yep mine is working too... Using provided kernel with ROM... Going through my PC/Linksys router.
Have Swype installed and it works like a charm.
it won't let me restore my last backup of my previous rom, check of MD5 sum failed. It let me make a backup of this ICS build, however. I do want to go back to the other rom I had before til this has camera and such working, and I didn't titanium anything cuz I just wanted to play with ICS.
Any ideas?
PS thabjs for the quick response earlier about settings. I actually was asking about the caoacitive menu but on but that I see has been reported as a known issue. We're good on that!
Yes it has been awhile since seeing you around Hero.... Wouldn't mind seeing what inthebox mentioned or even some bits and pieces of it :)
Reactions: intheb0x
Got the lock clock font working!
Several ics font packs have a clockopia font, but they are not all the same. One that looks right is in the package in a thread in the wildfire forums on xda. "Android 4.0 ICS Stuff"
You then have to rename clockopia to AndroidClock and paste in system/fonts folder.
I know i thought it didn't i need to edit first post thats all.lol
thanks hadn't messed with other KB's yet.
Any ideas?
Try a different back up sounds like you just have a messed up nadroid it happens sometimes. If you don't have another then wipe everything and flash the rom you were running.
I sure will be getting ahold of Hero that great of him to offer to help. :)
Reactions: intheb0x
Status
motoJunkie1
