[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
I love this, thank you.
Two questions:
  1. Does the notifications panel work on the lock screen? I can't slide it down or find a setting to allow me to.
  2. Why does the clock show up twice on the lock screen? The Galaxy Nexus doesn't do this.
Small things I know, but just some things to keep an eye on.
I can't push the notifications panel back up after I pull it down. I have to use one of the soft key buttons to exit out of it
Sent from my Nexus S 4G using Tapatalk
Reactions: jeffreynothing43
Sorry man i look from pages 59 to your post and dont see anything about titanium restore issues. I do have root with SU working Titanium can remove apps but not restore it just sits there forever...what weird is there used to be an apps processing mode that i cant find now.
Anyone actually restore apps via titanium yet? if so can you check preferences for me and see if apps processing mode is there for you?
Haven't used Titanium but My BackUp Pro worked fine for me :)
the whole app it happened after restoring data with mybackup
This is my bad for not making a very detailed first post yet. The problem is restoring apps right now not a good idea probably going to give you a lot of problems. Wipe and install everything manually for now.
I'm debating whether or not I should attempt to modify Launcher2.apk I haven't even taken a look at it yet. Does anyone know if the launcher "App Drawer" icon is in Drawable-hdpi? I might have to install Windows 7 again. Linux is quite powerful, but I don't think I really need it right now. It's just holding me back. So, ill be back updating my patches in a few hours
Anyone else having this issue? What should I do?
That's what happened to me when i was charging the phone while using it.
I think it's normal for the touch screen to act weird while charging. Every android phone i've owned did something like that
Beezy, I noticed that Flash doesn't work. something probably to do with hardware acceleration maybe? (Sound works fine, video is a no sho)
The youtube app took a few tries to open, i played a video and it looked a bit strange
From what screen. I'm confused.
What do you mean what screen you just said you pull down wouldn't go away.
if it gets stuck then use the buttons to dismiss/close it.
-Back
-Home
-or holding power then press back
Is the sdcard available to read yet on the rom? ...... everytime I try to get a file from my sdcard... is a no go.... music .... photos... anything that I had there wont show up all tho when I took a new picture with beta2-1 it show up but just the pictures that I took ...
ok been running this since 10 a.m. and had my first problem. Not sure if this has been mentioned earlier [thread almost doubled why i was at work way to much to read) wifi connected at my office but when i got home it will not connect to my home network. connects for a few seconds then disconnects. Beezy other then that runs smooth like butter!!!!!
I should be able to swipe it back IP though...
It'll probably be like that for awhile,I don't think to much more can help the overall performance of touch.
It works for me ive played music and used astro to delete files.
The torch doesn't seem to work.
But this browser is really fast. I can't even imagine the final is release!
The voice-thingy also seems to work pretty good.
Try this
-remove all the networks
-turn wifi off/on
-connect
If it still doesn't work
-remove network
-reboot
-try setting it up again
Let me know if that helps.
Status
BNI direct
