[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
I know all the basic issues that guys are seeing,the main thing is the touch screen. The two finger thing is a PITA.
To everyone theres a lot that needs worked on and somethings that needed to be fixed again,i started over earlier and got luck to have 3G connect so i tried a few things then uploaded. I really was just going to try get it booting as a joke but got lucky so figured on start working and release for everyone to enjoy and help. If you do come up with anything at all that helps tips tricks changing things cool share with everyone just as i am,Ill gladly give credit and take any help. For now im going to get sum rest enjoy the new two point touch :confused:
Sir, I would like to help you out. I tested it on Nexus S and it is booting, hope to continue this, i am posting a thread for ns at xda with full credit to you. all i will do is update it there whenever you, i or any other dev progresses. ty
Reactions: beezy
Okay make sure to give credit to pete alfonso for his kernel too please I respect and like his work thats why i used his kernel and his files.
Ok, so I flashed this on my Nexus S GSM and it boots fine and everything, but I still have the same problems as everyone else.
Non-calibrated screen, capacitive buttons doesn't work, glitchy screen and all that.
But it's surprisingly fast for a SDK port.
Hah, I already got kinda used to use two-fingers.
Probably a hardware issue or kernel issue try flashing a gsm kernel this is built with the kernel from pete's cdma release don't know if the kernels are different. Has to be a anykernel type of zip.
Edit* does data/3G connect for you?
Status
Haris18
