[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
sorry was delayed, i'm posting my nexus s 3g modified version at my site soon for those who have been following and want it it should be up shortly.
What's new in it so I know what to expect for the 4G version
Sent from my Nexus S 4G using Tapatalk
I must be the only one that had Wifi working from the start lol.
Had no problems with it. Have a few freezes that lead to a reboot if I install new apps but now that I have it set up I'm fine. I do notice the camera starts like flashing but getting out and back in seems to fix it.
I deleted the google apps shortcut off my homepage and am currently looking to try it again. (Of course)
Dont see it under the widgets tab of the app drawer.
Any ideas?
Any ideas?
It's not a widget...it's a folder. Just drag all the apps to your desktop and then place one on top of the other and it will form a folder. Repeat this with all of the apps and then rename the folder to Google Apps :)
is the menu button supposed to work on the main dashboard? Just question :) and do current kernels work on this build? Thanks in advance!
I don't think so because there is not going to be a Menu button on the Galaxy Nexus, but if you need to change anything you can just go to... App Drawer > Settings. Good luck.
Well look at it this way everyone... We all part of a small group of lucky ones getting a chance at running ICS in very good form before its even out on any device...
That alone is worth it all in a nutshell... The kernels, and other goodies will be here soon enough...
Status
tabpro
