[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
what powervr driver on kernel side do you use? It's from omap?
oh, nevermind I got it working using omap4 driver... finally ICS on Fascinate... but is this ICS from Nexus S that the video has been leaked sometime ago?
Is the speed able to be tinkered with? With the help of set CPU or installing a compatible kernel? :)
Sorry if its a stupid question lol
Lol
Beezy,
Is this compatible with the g1?
-sarcasm-
Sent from my Nexus S 4G with Ice Cream Sandwich
If you have installed SU then you should be able to use turn on CPU governor in setCPU But I wouldn't try to Overclock / Underclock.
Reactions: beezy
Sure,wipe three times. Then goldcard flash our bootloader flash six times pull battery wait a year reboot.
I kno u said to wait a year, but smoke came out the heaDPHONE HOLE. iS IT SUPPOSED TO DO THAT?
I'm done now lol
Rom is very smooth, most of apps all are working for me had one issue with astro file manager when i downloaded it from the market it wouldnt access the folders it just would highlight over the folder that i clicked on but when i went to use another file manager it worked perfect so don't know why i had that small issue with that but everything else is working perfect installed swype on it and that went thru flawlessly so great work. Thanks Beezy!!
Reactions: Charles Dolly
Yeah it might just be an issue with the ROM or it might just be a problem with astro and 4.0
Reactions: beezy
anyone else having trouble getting adobe flash working?
I'm on 11.0.1.153 and I keep getting that lego block icon every time I load flash sites.....is it not working yet?
Hmm... I haven't heard of anyone else having that problem.
I have experienced this as well, usually when the phone is charging but occasionally when unplugged as well. I second the suggestion to try plug and unplug.
Sent from my Nexus S 4G using Tapatalk
Status
wobblefix
