[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
I was able to pull the Google+ app out of the dump and it installed perfect. Its the updated one in the market too.
I still wanna try though. :P
I'll just wait for your update anyway.
Gotcha just wanted to give you the heads up ;) It's different as you will see from size it's a little over 11mb.
Okay I'm done taking it off topic but batting I'm sure I'll be in touch later on after i get a few things done.
Reactions: Batting1000
Great, let me know. :)
You are not to post the links they have been removed. I respect all developers and expect the same from everyone in the forums. I waited to download and so can everyone else.
GPS has always been that way with this ROM, I only changed the launcher, nothing else.
Sent from my Nexus S 4G using Tapatalk
I just never had issues before, maybe it was some issue with the gps sats themselves.
Thanks for clarifying.
Sent from my Nexus S 4G with Ice Cream Sandwich
I'm actually getting constant Google+ force closes after installing this. Gonna try wiping the data on the Google+ and see if that resolves it.
Sent on Ice Cream Sandwich from the future of Android
I have seen a couple posts with people saying that titanium backup wasnt restoring for them, but no answer (here is my search http://forums.androidcentral.com/search.php?searchid=2910913).
this rom is amazing work... especially for being an SDK port!!! gonna use as my daily for a bit. However, i am having an issue referenced above. titanium backup just wont restore. It stops at 0% and will stay there til i kill the app. Any work around for this?
my backup root/pro works just fine for most apps. I did get a few force closes after restoring with mybackup, but I just copied the apk to my sd card, uninstalled the app, then reinstalled from the saved apk and it was fine...even restoring the data with mybackup afterward worked ok...it just corrupts the app install sometimes for some reason.
Titanium doesn't work at all for me, btw.
Reactions: frettfreak
No dice for me - I wiped data (w/ Titanium), rebooted and now it FCs on start. Guess it's back to 1.2.0 for now...
Can't remember if u can do this with the free version.......go into preferences > app processing mode and change to "interactive"......worked for me! Someone else had pointed this out either in this thread or over in XDA. My appologies for not being able to give credit.......
Long days and pleasant nights............
NICE! Just did it. havent tried all the apps, but at least they installed!! THANKS A TON!
already got it fixed with mybackup root... but will try this too as i have the TB pro version.
I love this rom, and its exceedingly difficult to switch back, but I've noticed a serious issue with my battery life. With light use, texting occasionally, no phone calls, no browser, wifi and GPS off, etc, I get about 5-6 hours. I'm not sure if this is a problem with the rom or something with my phone, but it's almost rendering it unusable because I need my old battery life back. I love this rom, but I need that battery life back. Any help would be appreciated! :)
I hope beezy steps it up ;) Drew says face lock is coming to his ROM!
Reactions: tylerwatt12
Either Drew has a lot of free time on his hands (more so than beezy), or for some reason working on the 3G build is that much more easier. Either way, kudos to both of them. They are doing things that would only make my head explode if I tried.
Status
andiox
