[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
So, I still have the original 3.2 build and was going to wait since the official Nexus ROM is being worked on. Do you think this is a good idea or should I go ahead and install 3.5?
Install 3.5, its a bit snappier. We'll be testing the new version soon, won't give an eta though, mostly because i'm not sure :P
I really don't care about an ETA at all... what I'm interested in is what changes (more speed improvements?) the new version will bring. Can you comment on that at all?
Patience is virtue...
...no something & no ice cream something make me go...something something..."Go crazy???" DONT MIND IF I DO!!!
All I can hope for is battery life it really suck on lite use I get maybe 4 hours just texting and phone:confused:
I had the same issue with battery life when I first flashed. Then I started all over. Redownloaded the ROM, did a fresh install after wiping everything a few times, and made sure to deny Google restore when I signed in. After that........golden. Not quite the life I was getting with cm7 and matr1x, but still very good. Getting a good 10-12 hours with good use.
Long days and pleasant nights............
Battery life for me one day can be amazing and then the next charge its dead quick. I hope we can get it adjusted but its really hard to get a good baseline for me at least cause I'm usually flashing or checking things out a lot more then most probably are. I do know that if i disable the gps unless needed battery is a lot better. It's set on by default in the rom.
Are there any new wallpapers, static or live, in the new system dumps?
Sent from my Nexus S 4G using Tapatalk
(links removed by moderator)
I am sure he already has that it dropped yesterday.
@Beezy I personally don't expect any kind of custom anything when it comes to battery anything. I know that is a different animal. I am overly pleased with how this has turned out so far and thank you guys again for all the hard work.
Reactions: beezy
Not that I found... It appears to be what is already in circulation.
Ringers/notifcations/ui tones all appear to be the same as what we have already seen in GB or various ROMs... Nothing new there unless something will be changed at official release.
Reactions: beezy and djw39
Status
jeffnachatilo
