[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
I am getting these texts too.. Very strange.. Using RC4 but I was also getting them on the xda version as well.. Also getting sleep of death at times on RC4..
CM9, Codename Android, AOKP, And AOSP based ROMs are all getting these texts. Ive heard it has something to do with emergency broadcast texting. Idk
Get me a logcat as soon as you experience the "Sleep of death". Its most likely a kernel issue. I wont know til I get that logcat :)
Its based on the same AOKP Source code but I never got around to looking at times_infinity s newest build. Mine is a lot faster and gps now works correctly.
Thanks I have not checked out his latest build either, I am on build 40 from times if that means anything to you and overall its good. I guess I will try yours next to compare.
Build 40 was basically a "Nightlies" build. Milestone 6 was a "Release Canidiate" build.
Dark, I know you didn't build these roms from scratch but porting and compiling and tweaking is still work. Plus you've answered all my questions I've had while trying to learn this stuff without flaming me or being an ass. Throw up a link so I can donate...
Sent from my SPH-D710 using Android Central Forums
I second this motion. I'm not sure if he already posted or not, but I will :D
Sent from my piece of expensive plastic and silicon.
Re: [ROM][July 19, 2012] AOKP Milestone 6 [RC][Nightlies]
I see you have a recommended modem link? what modem is it?
Well I'm just happy to know that I'm not the only one getting the texts and its not hackers from Russia injecting aliens into my phone and uploading a virus to the pentagon. So its all good ;)
I'm changing some settings and rebooting my phone. I've got this bug where after I reboot my display is stuck at full brightness whether I change it in menu or not. Also, notification led is not working. Gonna mess around with some settings to verify.
I can't get brightness to go down no matter what I try. Thinking about reflashing from :(. Damn it, right after I get everything set up.
Nightly or Release Candidate?
If it's a nightly, he asked ub the OP not to report any bugs as nightlys are unstable OSes.
If it's a RC, then fire up them bugs, but shouldn't expect a responsible. I think he's busy atm.
It was the RC4. I'm flashing the nightly right now though, gonna take it for a test drive.
Edit: Off to a great start. Noticed notification light is already working :D
Well.. thought I would reflash to see if it remedied my problem with sod.. did not have an sod yet but did.experience a 4g disconnect as on the xda rom. 4g disconnects and.grays.out and says that it is turning on and just stays like that. Also got my first Los in a while. Screenshot attached for 4g error but logcat.was.too big.to attach.
I anyone is curious, none of the bugs I had are present in the nightly. I just went through all the settings and tried to recreate the bugs I had several times. Everything is working perfectly.
Also, I FU**4NG LOVE AOKP. Seriously, it's amazing. To the guy reading this right now who has a stock setup and is trying to decide if he wants to root and flash a rom. Flash this sh*7 immediately. Yes you. Do it.
Running RC4, with modem and S voice. No problems at all. LED works fine. Battery life and performance are great. Quadrant is considerably better as well.
Thanks Dark Knight :D
Sent from my SPH-D710 using Tapatalk 2
My benchmark scores are considerably lower than stock especially with antutu but I'm calling BS because this rom is much smoother and snappier.
If anyone wants HD YouTube with this rom since it doesn't come preinstalled with gapps then download this...
http://www.4shared.com/android/I4_eLWIX/YoutubeHDics.html
Then push it to system/app/, rename it to "Youtube.apk" and reboot phone. Works great and looks 10 times better than the regular YouTube app. Try not to get lost in the nether realms :P.
so can this be flashed from any cwm.?
I comes with safe recovery?
Hey....how dare you mock the pick unicorn boot animation. :thumbup::p:beer: I am deeply offended by your desire to change it. Lol
Im just messing. :)
Yes this is bootanimation.zip supported by default. Just look in /system/media/bootanimation.zip. Delete the default one and then add yours. Change permissions to "chmod 644" then reboot.
Can you do this with any picture.?
Status
texanmason
