[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Ok so its almost lunch time and i can finally do this. Another question just to be sure...once Im on el26 am i going straight to flash or am i wiping everything first? Im on aokp milestone 6 with Chris kernel.
Sent from my GT-P7510 using Android Central Forums
Just wipe everything to be safe.
Sent from my SPH-D710 using Android Central Forums
Sorry one more thing....first time i use mobile odin. Once i select el26 do I just go down to select "flash firmware"?
Times_infinity source kernel has persistent issues with 3g and 4g. Dropped data, slow reconnects. SOD/hard resets when 4g is active and the screen turns off.
I appreciate his hard work but nothing has been done about it since before the 7/20 build which is pretty redic
Sent from my SPH-D710 using Tapatalk 2
Noticed the same gonna try a different kernel today
All done and installed. Thanks for all the help. I'll update how its working for me this weekend.
Hey Mr. Dark Sir, do you reckon I could safely flash Stable 4 on top of RC4? Lol yes RC4.
Have you been living under a rock???
I have flashed multiple builds, including newer aokp builds you have released. However, all of them fail compared to rc4. Stable 4 seems comparable but I don't wanna mess with perfection so it ain't worth it to me if I lose all my data.
Anyway, I'm still on jellybean. I was just curious because jelly is not smooth at all compared to aokp.
It's the same source correct? So I should be able to flash it dirty yeah?
Let me pull Times_Infinitys newest kernel from his AOSP Rom. Lets see if it plays well with AOKL
If it has the stability of your repack with some of the bug fixes from his that would be so gravy!
Chris's "wtf" kernel is pushing this rom really really nice. Haptic and everything works flawlessly also. Only thing is the backlight for the touch keys is still buggy. I keep mine off anyway.
-AOKP milestone 6 - FH13 Modem - Cobalt theme
Reactions: vmini91
Crap!!!! Why can't I just have my cake and eat it too. Having sd card issues.
Flashing a Chris FF18 repack.... wifi borked.
Flashing a Times Infinity...
Soft bricked...
Unable to boot into recovery...
Able to boot into download mode...
Attempt to Odin FF18 - - -FAIL
Attempt to Odin EL26 - - -PASS
THANK GOD!
how's is it when u go into sleep when 4g is on. then it tries to reconnect? I found a bunch of times when I'm on chris41g kernels after waking it would show 3g but the signal was grayed out and I'd have no data.
Status
MisterVoltio
