[ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Updated)
Is there a way to pull the beats audio and xloud to put them in a different rom? Also the same for the 3g oak and v6 tweaks. I just don't like script manager and would like to be able to run it in terminal. Thanks in advanced
Is there a update yet I've been playing with aokp , joyos just wanted to know :D
AOKP, G-T-R, MiRaGe, Godzilla, JOYOS, Harmonia killing the game!!!!
The eglpatch works awesomely on this rom, I think I'm gonna keep this as my daily driver :D
Sent from my LG-E739 using Tapatalk 2
Re: [ROM-CM7-PORT] G-T-R Reloaded 7.8
Waiting for Neko still. Lol. :)???
I just tried to install this ROM unsuccessfully I have cannibal recovery 1.2. It says the ROM was unsigned, does anybody else have an issue installing it? Currently I am running TDM ROM.
Turn off signature verification.
Yes. Install zip from SD Card > Toggle Signature Verification.
I domt see a need to flash zips anymore :P
Could you share the steps you took that worked for you? Did you simply follow the recommended settings in the op or do something differently? If you simply followed the steps in the op then let me ask what version of the optimus do you have? I have the old optimus with the older screen and radio.
Sorry for the late reply, I have a newer optimus, I think. Zv5 radio. I followed the recommended settings, rebooting after each step, that's all
Yes. The reboot is a must to get the patched items.
thats where i put it... :-)
I know how to do it now. I read it, and I need the com.android.name of it :P
@Everyone, Neko told me he didn't get my PM, re PM'd him. Hopefully he says yes? :D
Reactions: O13 and inceyet
Just wondering there's a problem with it no letting me set ringtones? Is this a known problem?
Are you click OK and.not Cancel?
If you use ICS alot, you get used to ok being on the right and not the left
:p
Reactions: topdawg661
slide your notification bar down, check toggles, and make sure your phones set to loud and not silent or vibrate?...
Both didnt work :'( i got the notifactions to work though go sms but phone calls dont work :/
:p
weaversweb
