[ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Updated)
Or try setting a music file as your ringer it works for me as well as notifications both Android system and music. Hope this helps
For some reason they started working? Thanks for ur guys help![:
well I took the plunge and decided to try this. Best decision of my life. I used that wifi afterburner and holy crap. I downloaded a 2 MB app in a second. I'm normally at 500kbs. Wow
Not sure if this has been reported (not searching 21 pages, I have better things to do) I can't switch the lock screen style. It switches right back.
Re: [ROM-CM7-PORT] G-T-R Reloaded 7.8
Where did you get the wifi afterburner? is that build into this ROM? Thanks.
That's odd. Everyone seems to have different problems. Its flawless for me.
Ill sync this with the latest Mirage, for a final release.
Ill release Ginger Snap soon. Neko said " Permission granted " :):D
The only two issues I got and I'm coo with cause the rom is a beast it when searching the blank screen issue and the bt issue when disconnecting the but or pausing my music I gotta re-pair the bt cause it won't connect again aside that this is my daily
Try downloading this to you PC(Windows)
http://www.lg-phones.org/wp-content/uploads/LG-Optimus-V.zip
Ill do a final update to slim it down and sync with the latest Mirage for speed. Maybe add a theme without transparency too. But keeping the GTR theme. :P
Transparency kills speed.
How about making it completely xperia themed? It's already using the launcher
Can't wait for gingersnap!!! But until then this is what I'm rocking(:
Haha. Maybe ill make a themed rom. I'm actually running an Xperia themed rom by me. I keep it as a backup. :D:P;)
i am not a noob, but how are you accessing usb mass storage, i connect my usb and have no USB pop-up notifications? Are you accessing it over recovery?
i use ubuntu... ive never had it not show with any rom... if your on windows, you may need to reinstall the drivers...
clive
