[ROM-July 31]G-T-R Reloaded 7.8.6| Gaming+Beats(Root Fix Updated)
Not bad. Try V6 and Kak in Terminal Emulator
If that's your score without v6 supercharger and kickass kernelizer then Idk what to say xD because That's what my score looks like WITH v6 and kak xD
G-T-R & Quattrimus CM9 Nuff' said.
(Also, sent from my LG-VM670 using Tapatalk 2.)
Quoted the wrong person sorry xD
Relax, it has been said before, those scores don't really mean anything plus not all phones are equal
Here's with the experimental 1 setting for the 3g.
I'm not hyped up or anything I'm just quite impressed that's all :)
I'm having to reboot whenever I want to toggle Wi-Fi on or off
Re: [ROM-CM7-PORT] G-T-R Reloaded 7.8
is there any way to change the font color on the status bar? im not liking the blue...hard to see
Edit the theme, go to the XDA thread, and get the remove center clock patch.
I have a question kind port master. When I go to the terminal to update the busy box using the 'updatebb' command as described in the tweaks, it says the command is not available. It doesn't really seem to be an issue however because the busybox version that comes with the rom works with kak and other tweaks however.
Just wanted to know if that was something that was taken out or if it should be there?
Also if I try to update busy box using anyother method I get an error about permissions and cannot get busybox back without a reflash. Thanks
Not really good with Busybox. I don't understand it. :)
But I know Neko upgraded it to the latest I believe, so its not needed. I think the command was removed. I could be wrong. To check the terminal commands, go to system/xbin
Anything there can be typed in.
Reactions: kenharkey7
This rom is amazing I love it. The only problems I have are that apps lag. Video lags. Play store is slow and lags. And the web is slow. Lots of FCs.
I don't understand why its not being used enough
Would Fix Permissions work for the FCs?
All in all, this looks and sounds like a great ROM. Surprised it's so under the radar. Never been too crazy about the blue ICS status bar look, but I'm sure there's ways to fix that. :)
Nope, tried it. Both using the emissions terminal command and from recovery
Opoliraka
