[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][PORT][JB][07/30/12]CyanogenMod 10 [BETA 1]
Rebooting is having trouble, it just sticks on the screen that says rebooting.
Google Search is FCing from time to time.
Opening camera brings a notification saying "Gallery Force Close" Then throws me back to the main menu.
Thats what I've encountered so far.
I also flashed Beta 1 from CM6, no hard bricking, but I'm not saying it's safe to flash from CM6.
Anyone using FF18 and have Beta1? If so, can you post a review video on YouTube? I am wondering if I should install the CWM recovery QBking77 suggests...he says its safe to flash any ROM with it.
Also whenever I plug in my charger it reboots on beta 1
I'm getting, "Unfortunately, Google Search has stopped" over and over again immediately after flashing and setting up Beta 1. Anyone else experiencing the same? And yes, I wiped everything I was supposed to.
Try removing google search from system folder and reinstalling it from the market.
dk root access is broken , torch is broken , gps still broken on 3g works on wifi.
Also, oddball issue: the Play Store icon in the top-right corner of the launcher doesn't work. The Play Store app does, just not that link to it.
EDIT: Never mind, started working after a crash and reboot.
beta 1 notes so far:
3g works - but switches to 4g within a min or two same deal with 4g
4g took a while to turn on
once i rebooted phone was just being sluggish calls were having a hard time being made and hanging up (sometimes)
SU is not granting any access or updating binary
i still have the voicemail notification i call it and says i have no voicemails (phone says i have 5)
phone randomly wakes
google search works and talks back
i would test market apps but im going in and out of 4g
thanks for the hard work Dark!
second that nothingsblooms: no root
also, im still getting random wakes (not as often as alpha 4)
and thanks for whippin out these updates so quickly, been flashin like mad lately
Registered just to say thanks DK for all your hard work! Sure there are still issues, but holy smokes, what you've pumped out in such a short period of time is impressive to say the least.
Thanks again!!! :)
Reactions: ffolkes
And if you plug in your charger it will reboot your device turn off your 3g or something weird like that.
If it doesn't do that to you It might just do that sometimes and yes we have no root access with superuser.
Running Root Explorer instantly reboots the phone.
EDIT: Okay, running anything that requires root reboots my phone. Going back to AOKP for a little while while this stuff gets ironed out. Great start, though.
Status
off8485
