[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
Re: [ROM][JB][08/03/12]CyanogenMod 10 [Beta 4]
DK, did you intentionally delete /etc/init.d in RC1?
Anyway, so far so good! RC1 has been running for like 10+ minutes, and not one single random wake! Cpuspy shows deep sleep at 72% :D
No I didnt. its all back now :)
sweet ill post back if any issues come up!
Deep sleep fixed, no wakelocks! Good job man, as far as extended volume settings seems to be working you added the 3 options at the bottom for silent/vibrate/ring correct? If so then it is working just fine. Only issue still remaining it seems like is bluetooth media... oh and video camera while in playback still gives black screen, Nice job!
Sent from my SCH-R760 using Android Central Forums
I see that it hasn't been changed in the Op but wasn't sure if it just hasn't been changed yet. Is the SD card visible in RC1? Or is this still being worked on?
Regardless, thanks for the hard work and great ROM. Many thanks.
SD card, completely visible here.
Hmm... if you tap the screen while the video camera is playing back a video it stays on... wondering if there is an issue with some sort of timeout setting for playback initially??
Can anyone confirm this??
With RC1...
What GApps are you all using to not have screen wakes or LoS? Are you still getting dropped calls and issues with the phone app?
Does it at least work now? Beta 4 had Gallery, Camera, and Video issues which should have been resolved in RC1
hmm... that works to an extent, can anyone hit the settings button, mine comes up a split second then goes away but from what I can tell it says crop, details, etc, etc. I am referring to any of the settings in camera, will not come up.
edit: also , every once and a while when I go into battery settings the phone will softboot. I will start a logcat and post if I can get it to reproduce.
Yes , I was able to reproduce it doing the exact steps:
Go into camera and hit the settings button on the phone (by the home button) then go into regular phone settings and go to battery, the phone either freezes or reboots. I will attempt to see if it is on the logcat.
Status
waqar53
