[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
From OP:
CM10 RC1 Release Changelog:
Reduced LoS (Better then before)
Reduced Battery Drain (Better then before)
Added New Build.prop Tweaks
Recompiled and Recoded Sbrissens JB Kernel (Developers: STOP ASKING FOR MY SOURCE CODE)
Added Extended Power Menu (Sbrissens Source code)(Huge Thanks)
Added In CM10 Theme Chooser
Added Some New Upstream Fixes (CM10 Source)
Fixed Sleep of Death
Fixed SU and Superuser (Chainsfire)
Reverted to old 07-17-2012 gapps
I do not see CM10 Theme chooser? Is this apart from the link you have in the thread?
Well that is a big fat no freaking duh. Adobe Flash mobile has been discontinued. Adobe already announced they will not be updating Flash for Jellybean. Adobe Flash player is dead now. Sorry
You speak my thoughts. Also, testing your new RC1. Bug report: Titanium Backup made my phone hot. Kidding. Nice job. You're a kicka$$ guy and a tribute to the force! Thanks DK.
Reactions: Dark_Knight2
From OP:
I just checked the zip and it is indeed in the /system folder
ok i read and read and read and still see no answer if you can make and recieve calls??? I had to go back to my daily becuase i would always run into call problems i could careless about 3g. Can anyone confirm working calls without rebooting or doing other stuff please thank you. so i can flash this bad boy....again (15th time lol) ;)
Here's a "trick" that might help some people out. After you install RC1, don't do anything with it. Don't install any apps, don't restore a backup, don't do anything to the ROM, other than use it for phone calls and texts for at least 2 hours. I'm serious. Use the phone bone stock for 2 hours and report back how the ROM is behaving stock.
Please try this...
Flash also works on JB. If you side load it or use titanium backup.it works as good as on icecream
Sent from my SPH-D710 using Android Central Forums
Do you know how hard that will be?! Lol so no browsing? I don't make much calls but still lol
Sent from my EPIC 4G Touch!
Status
profarmapramshop
