[ROM][KANG][08/05/12]CM10 Release Canidiate 1
Status
Not open for further replies.
hmm... that works to an extent, can anyone hit the settings button, mine comes up a split second then goes away but from what I can tell it says crop, details, etc, etc. I am referring to any of the settings in camera, will not come up.
edit: also , every once and a while when I go into battery settings the phone will softboot. I will start a logcat and post if I can get it to reproduce.
I believe we need a true JB kernel for that to work. I will look and see.
Yes , I was able to reproduce it doing the exact steps:
Go into camera and hit the settings button on the phone (by the home button) then go into regular phone settings and go to battery, the phone either freezes or reboots. I will attempt to see if it is on the logcat.
I was able to confirm this once, but not anymore. Hmm.
Reactions: nothingblooms
what am I looking for???
more towards the bottom any reference to it freezing after attempting to go into camera settings and then going into battery. I'll post back in just a minute to see if I cant pinpoint it for you.
Nevermind, ill start a new one, anyone know how to clear logcat in terminal?
it wont let me instal any apps must be the jb app zip can you share a link with the one you flashed or maybe lowriders
Sorry to be the massive newbie here, but I'm just trying to keep up with all the terminology; what does LoS stand for?
Also, I lost root access but still have a custom recovery (running beta 3), would restoring my nandroid in this recovery be safe?
Sorry to be the massive newbie here, but I'm just trying to keep up with all the terminology; what do LoS and RC1 stand for?
Loss Of Signal, Release Candidate 1 and no. Odin to EL26. Also might want to use a daily driver like CM9 or AOKP.
Flash isn't supported on jellybean. Its not going to be either.
Sent from my SPH-D710 using Android Central Forums
I can't download adobe flash player from market says my device is not supported
Well that is a big fat no freaking duh. Adobe Flash mobile has been discontinued. Adobe already announced they will not be updating Flash for Jellybean. Adobe Flash player is dead now. Sorry
Status
profarmapramshop
