AndyOpie150
- May 15, 2011
- 1,254
- 32
- 0
Wife just got this phone and it does not disappoint. We do have LTE in our area, but really for me its not that important since I have wifi at home and at work. The battery in this thing is a monster, heavy use and lasts FOREVER. This is a Very nice phone for the price point, good camera and instantly Syncs to cable box or satellite provider to double as a remote control. I was impressed by this phone but as I said earlier I'm going to squeeze every last bit of use out of my V, this will probably be my next phone as the S5 is $600 and the S3 still too pricey.That is interesting, but be sure to check coverage before jumping. I just checked for my address and Virgin has Wimax here rather than LTE in my area in the heart of Silicon Valley. The Volt doesn't list Wimax as one of its features. And I suppose that the spark version of LTE will be available in a lot less areas than traditional LTE.
T-Mobile does have LTE coverage in my area and I have the new model Moto G LTE on order from Amazon.
Also, although the Volt comes with kitkat, virgin has conditioned me to not expect any significant updates while Motorola gets all the new releases. The Volt price is attractive, though - $180 vs $220. Options are good!
the gapps have to be flashed with the ROM for the setup wizard issue.Hey...bigsupersquid...
This ROM won't install at all anymore per se: the boot animation is blurry, and once the setup wizard shows up, it crashes the moment I press start...
search the ov rooting roms and hacks forum for multirom.Is there an OS2SD version of Mirage thats similar to this setup?
There were originally problems with audio routing between phone earpiece and speaker in the kernel way before kitkat.Running the ROM now. Amazing, root uninstalled a few of the system files, I've got gmail, battery doctor, dolphin browser mini, Android music player, sports tracker, and inkpad squeezed in. It takes away the gaming option (which is good for my family).
Snappy speed, beautiful, running nice and quick at 480-600 for the clock.
One thing, do you have just the speakerphone fix separate? I don't want a full update, just a fix.
It routes all calls to the speaker, kind of not super private.
AMAZING ROM! Love it, it's my daily driver.
28 hours on this ROM on a full charge, only had 24 on SlimBean (with battery doctor)
boot animation is half-res to save space.
Your nand doesn't flash well either, unless you've replaced the phone... but if it gets as far as setupwizard it probably flashed ok.
And the only remaining issue seems to be clock lag that only affects the time displayed on the status bar and any clock widgets?,,.
The alarm fails often.
But the clock lag is the big unsolved issue. If I could get a build past March 15 to boot maybe it'd work.
Oh, and the compass might not be working right.
Have you tried the os2sd? I bet your sdcard is more stable than your nand....ahhh, scrap.
Still a no go, bigsupersquid. Even doing ROM+gapps, once it boots up and reaches the setup wizard, the moment I push start, the wizard crashes and renders me unable to do anything.
And it only gets stranger: once back in recovery, it wouldn't restore the backup I had made! No idea how that happened, the nand backup process went fine, but every restore attempt got hung up with an error "during restore sd-ext".
Stranger still, despite the recovery recently REFUSING to flash or restore backups of anything below CM11 (which hadn't been a problem before as I have both a CM10 nand and a BeanWhiz nand), I tried to restore one of my other nand backups...and it restored the BeanWhiz one successfully! Admittedly...I am stumped.
Something similar happened to me, where my phone kept constantly rebooting. Got frustrated and tried to restore from Nandroid. I had 3 different restore points and all of them failed to restore. I remembered that a few days back I had dropped the phone( pretty hard) so maybe the sd card got jostled. So I removed the micro sd and re inserted. Problem solved.Have you tried the os2sd? I bet your sdcard is more stable than your nand.
I'll need to have a bigger sd card for that, lol. I don't think I'd have enough room to make the required partitions and then put on everything else back as well with the 16GB I currently have.
